Home > Wanted > Layshaft thrust washer 128-130 thou
alaskanow0
Member #: 8466
Mansfield
Hi guys. In mid way through my gearbox build. Unfortunately I need a dam3182 or dam3183 small thrust washer. I could work with 127-132 by using a different worn large thrust at the other end. Anybody got a spare kicking about. I have loads of 122-123, but nothing bigger.
Med recommend a minimum .007 thou endfloat for their Dogbox, which seems quite big compared to my normal 0.004 thou Clearence.
That said, MED like you to run most engine Clearances on the bigger side as well, especially on Race stuff.
Edited by alaskanow0 on 25th Mar, 2016.
Put a shim behind it? I did this on my last one...
alaskanow0
Member #: 8466
Mansfield
I thought about that, but what shim?
Coke can?
