| Home > Help Needed / General Tech Chat > Initial start up and Oil gallery plug leak .... engine now out the car, !OIL PUMP!? | |||||||
![]() 1733 Posts Member #: 1910 Post Whore Wilts |
27th Mar, 2016 at 06:50:17pm
Hi guys,
Edited by Oli on 30th Mar, 2016. On 15th Jul, 2009 fastcarl said:
the pissed up clown stood back up, did a twirl and left bollock naked, |
27th Mar, 2016 at 06:56:28pm
Sort the leak out, then as soon as you start it back up, straight up to 2500 rpm and give it the full 20min.
30th Mar, 2016 at 12:22:06pm
So the engines now out of the car, and ill be doing the gallery plug...
30th Mar, 2016 at 12:50:03pm
personally, with the engine out, I'd check the pump for peace of mind.
30th Mar, 2016 at 01:02:16pm
i think your probably right,
30th Mar, 2016 at 06:33:15pm
Those swiftune pumps are expensive. But worth every penny
31st Mar, 2016 at 10:31:02pm
Swifty one is great for peace of mind but sounds like you'd be fine on a standard pump.
1st Apr, 2016 at 08:15:35am
cheers lads, hopefully the new pump will be here today oil gallery plug is swapped,
1st Apr, 2016 at 12:55:46pm
did you check the pump to see if it was actually an issue? |
1st Apr, 2016 at 04:01:19pm
due to the fact i want to get the engine back in this weekend, ive just bought the pump on the off chance, ive yet to strip it down, but time will tell, i dont really want any more hold ups so just took the hit on buying it,
1st Apr, 2016 at 04:46:20pm
Makes sense |
1st Apr, 2016 at 06:54:03pm
My pump on removal,
1st Apr, 2016 at 08:09:03pm
41mm is tight |
1st Apr, 2016 at 10:10:24pm
Looks a duff one to me! |
2nd Apr, 2016 at 09:59:14am
New pump measures 45mm across the centre, that should do the trick!? On 15th Jul, 2009 fastcarl said:
2nd Apr, 2016 at 10:20:34am
Certainly sounds more in line with expectations. Bet your glad you checked it now! |
2nd Apr, 2016 at 04:34:42pm
I am very pleased I checked, but I've got you guys to thanks for letting us know and discussing these problems with! On 15th Jul, 2009 fastcarl said:
