| Home > Help Needed / General Tech Chat > Morris minor turbo(!?) | |||||||
17 Posts Member #: 10871 Member New Forest |
30th Mar, 2016 at 01:42:02pm
Hi all,
30th Mar, 2016 at 02:21:25pm
The standard Metro turbo engine made 94bhp and was pretty reliable. So I'd keep the compression high and the boost low which should be plenty quick enough for your car.
30th Mar, 2016 at 02:43:06pm
I tend to agree but i might be tempted to make provision for an intercooler anyway as you will likely want more power at some point and it would be silly to run without one at higher boost levels.
30th Mar, 2016 at 04:53:02pm
you need to do a bit more research on the pistons I think,
31st Mar, 2016 at 11:44:19am
And Megajolt on its own does not prevent det or piston damage. It needs to be mapped as appropriate for your engine and it,s fuelling,best done on the rollers. |
1st Apr, 2016 at 02:32:08pm
Thanks all for the helpful replies.
1st Apr, 2016 at 05:06:54pm
oil pump, swiftune is a good bet, recently its been discovered that some pumps dont seal properly as theres not enough land area and can leak into the end cam journel, the swiftune is a known good one.
