Home > Help Needed / General Tech Chat > Track Rod Ends upgrades?
jonny f
Member #: 9894
Dorking
Just bought a set of these, after needing to change out mine for the second time already with split boots.
http://www.ebay.co.uk/itm/271052184334
Anyone else tried something similar? Thoughts?
graemec
Member #: 1424
Carnforth, Lancs
How well will they sit in a tapered hole though - or will you need to drill that out to a parallel one?
You need to drill them out and then bolt them up against a spacer.
I ahevsomething similar, but never used them.
They are a lot of money them for some rod ends :-0
jonny f
Member #: 9894
Dorking
They are quite expensive for a set of rod ends. Then decent rod ends aren't far off the price.
Hopefully won't have to change them though.
