| Home > General Chat > Tig weling 1" 25mm 55 thou 1.4mm tubeing help needed | |||||||
12th Apr, 2016 at 10:28:29am
trying to sort the stupid coolant lines it aint happening for me this time i want to have the main part of the lines out of alu tube and just some simple rubber cuplings to the rad. water pump and head
12th Apr, 2016 at 10:35:09am
Make sure the cuts touch so your not trying to bridge, also tack in a few places and do shorter welds.
12th Apr, 2016 at 10:55:46am
If you're doing pie cuts....
Edited by stevieturbo on 12th Apr, 2016. 9.85 @ 145mph
12th Apr, 2016 at 11:19:48am
I use a larger tungsten for thin ally, a 3.2 I think, it doesn't concentrate the arc as much so makes things a bit more forgiving. Hard to say without seeing it happen, but I'd try a bit more amps. Soaking heat away into ally blocks is hindering you not helping, with ally its a case of getting it hot enough to weld as quick as poss, if you have a foot pedal then back off the juice a bit to avoid holes.
12th Apr, 2016 at 11:21:59am
Reading again though, sounds like you are making hard work when it doesn't need to be. Either use thicker wall ally, or easier still use rubber/silicone bends joined with straight ally if needed.
12th Apr, 2016 at 01:04:28pm
If it's hard to heat both sides evenly, put a blunt point on the tungsten, and use high freq pulse (maybe 120+ Hz). That will help stop the arc favoring one side over the other and can also make the molten puddle seem more viscous at the point it wants to drop through. Change the AC balance further towards 'cleaning' can reduce burn through on thin stuff by putting less heat into the workpiece and more into the tungsten /arc.
12th Apr, 2016 at 07:57:45pm
With 1.5mm wall you want around 100A max. Filler rod should be no more than 1mm otherwise it cools the weld pool too much and ends up lumpy. You won't need the full 100A to weld, only to start the weld, after that you need to pulse the weld (I always pulse weld by foot for more control on thin stuff) pulse your foot down until you melt right through the join (should see a C shape form in puddle) then dip the filler rod and back off to 30% pedal, then move torch and repeat.
13th Apr, 2016 at 09:47:29am
When I try and use thin filler...it melts long before it gets anywhere near the bit I want to weld lol 9.85 @ 145mph
13th Apr, 2016 at 04:42:18pm
That's because of the torch angle. 😉 it needs to nearly be perpendicular when doing ally. You can also move the torch back slightly as you dip the filler rod. https://www.facebook.com/pages/Fusion-Fabri..._homepage_panel
