| Home > Help Needed / General Tech Chat > battery testing | |||||||
12th Apr, 2016 at 11:26:01am
I'm sure someone will be able to guide me on this.
12th Apr, 2016 at 11:39:04am
If its gone completely discharged its probably goosed Robe.
12th Apr, 2016 at 11:44:17am
12. somthing amps or 12. somthing volts?
12th Apr, 2016 at 11:45:38am
I knew that's what I'd be told; I'm sure I got a 3yr warranty with it but can't find the receipt............ |
12th Apr, 2016 at 11:47:15am
12 something voltage reading was initially taken before I refitted the battery. no amps readings taken; the battery was re-charge for say 4 hours or so initially Edited by Rob Gavin on 12th Apr, 2016. |
12th Apr, 2016 at 11:57:06am
Euro have lion 063 battery for £35; might just buy one as i'll need something at some point |
12th Apr, 2016 at 11:59:47am
Hold off as long as poss, no point buying a new battery for it to sit about and go flat.
12th Apr, 2016 at 12:04:21pm
also battery wise, I always go for Varta if I can, good strong battery. On 28th Aug, 2011 Kean said:
12th Apr, 2016 at 12:06:59pm
I've bought a few Yuasa batteries recently for the 205's, so far so good, they come with a 5 yr guarantee from Halfords for not a great deal of £ with a trade card.
12th Apr, 2016 at 12:10:10pm
really need to get a trade card. a little impatient as the car is ready for oil pressure and I've no real way of jumping it in its current position |
12th Apr, 2016 at 12:21:41pm
Yuasa are another good battery,
12th Apr, 2016 at 01:34:26pm
As a guide, if a 12V led acid battery only has 12V it's fooked.
12th Apr, 2016 at 03:44:55pm
cheers guys. I've just called my local Halfords to see if I can blag a trade card; not holding out much hope but we'll see what we can do |
450 Posts Member #: 10396 Advanced Member Formerly mk2turbo Stoke-on-Trent |
12th Apr, 2016 at 04:20:57pm
Got any mates that work at a garage Rob? I just borrowed a load of old invoices for parts off a mate and told them I worked for him, gave me a card there and then |
13th Apr, 2016 at 08:29:11pm
Well i went up to the shed this afternoon and put the battery on charge around 4pm. Voltage at that point was 13.6. Went back up at around 7pm and voltage was up at 14.4.
13th Apr, 2016 at 08:51:30pm
How much fuel is in the Audi though? In the 13's at last!.. Just |
13th Apr, 2016 at 09:43:01pm
Lol! Filled up yesterday so aroung 3/4 tank. Now if i had some petrol in the metro, i could have had a go at starting it! |
14th Apr, 2016 at 05:27:17am
I have a 5a CTEC charger maintainer mainly because the battery on the skyline was a 1100A cca agm and my normal charger couldnt charger it
Yes i moved to the darkside |
14th Apr, 2016 at 07:46:03am
food for thought brett |
14th Apr, 2016 at 08:57:17am
I've had the same experience using a modern CTEK charger on a battery that has had some deep cycles. Always gets it back to fully charged and fully working. Well worth the money, and they are much cheaper than they were a few years ago.
On 14th Apr, 2016 Brett said:
I have a 5a CTEC charger maintainer mainly because the battery on the skyline was a 1100A cca agm and my normal charger couldnt charger it Anyway it is microprocessor controlled it does loads of stuff and one of them is to charger / recondition agm and lead acid batteries I had a couple new ish ones, same story as yours I left them out and they died this charger fixed them Its payed for its self imo and it can maintain all year round so leave it on the cars and it just does its job |
![]() 428 Posts Member #: 10128 Senior Member Dorset |
14th Apr, 2016 at 12:47:32pm
Found similar last week. Battery had "good" voltage reading after charge but died after a few seconds under load.
14th Apr, 2016 at 01:21:09pm
I've got no idea where my charger came from, never mind how old or good it is. Perhaps time for a replacement, although these smart ones are more expensive than the new battery! |
14th Apr, 2016 at 04:31:30pm
I have a normal £30 battery charger, and a hobby Turnigy 5a charger, mostly for charging my LiPo batteries etc, but I have bought completely dead drill batteries back to life with it for emergency use where the oem charger wouldn't recognise they were attached. Would probably do a car battery too similar to what Brett has. Might be worth getting one of these fancy modern LiPo jump pack/phone charger gizmos. I've fancied one for a while just not got round to buying one because they're not cheap. Most RC car LiPos can discharge at 30-40 C, so with a 5000mAh battery you're looking at a 200amp maximum discharge capacity 😶 On 26th Jan, 2012 Tom Fenton said:
