Home > General Chat > What start solenoid is this ?
fixitphil2
Member #: 10945
scarborough/ northyorkshire
Hi Iv been trying to sort the electrics on my new mini van project, I'm not sure what year it is but after looking into it it mite be a 1983 as I think it's got ballist coil electrics, can someone tell from this picture please
fixitphil2
Member #: 10945
The starter solenoid look like a four way one ?
I would say three, the fourth is usually on the opposite side to the start signal, the other one in the picture is just power feed to the ignition switch or fusebox or similar.
The extra (missing in your photo) terminal would be the ballast resistor bypass so not a ballast ignition system (or, if it is, it's not connected right)
fixitphil2
Member #: 10945
Ok cheers rod, il get one ordered,
