| Home > Help Needed / General Tech Chat > Ally Rad Source? | |||||||
265 Posts Member #: 368 Senior Member Roseville, CA (USA) |
12th Sep, 2005 at 10:19:59pm
I know these are dear, but does anyone know where one can purchase an ally rad for a Mini that is cheap? Is there a radiator off a scrapper that might fit and do a better job of cooling than the stock metro turbo unit? **************************************
13th Sep, 2005 at 07:27:20am
i got a brand new metty one for ?15 off ebay. its alloy with plastic end tanks. hoping it will easily do the business. |
13th Sep, 2005 at 03:27:30pm
Wow! That's a deal!
13th Sep, 2005 at 03:40:13pm
I think these are what you are talking about
http://www.twin-turbo.co.uk
13th Sep, 2005 at 04:40:38pm
A cheap way to achieve the same thing if you know someone good at TIG welding is to get an ally radiator off a more modern car, and then chop the end tanks off and cut the core up to the height you need.
13th Sep, 2005 at 05:46:04pm
Thanks, guys. Good thoughts!
13th Sep, 2005 at 05:52:16pm
Toms referring to the Rad having both the inlet and outlet on the same end. This means the water has to go down the red and turn through 90 degrees and return up the rad to the outlet.
Edited by Doodmeister on 13th Sep, 2005. Two things are infinite: the universe and human stupidity; and I'm not sure about the the universe. |
13th Sep, 2005 at 09:50:16pm
Yep exactly as Mr Dood says, you have the inlet and outlet at the same end, send the water down 50% of the rad tubes to the tank the other end, and then send it back through the remaining 50% of tubes. If you think about how the water will flow "diagonally" in a normal rad, the "corners" away from the pipe stubs do not get a good flow through their tubes, hence cooling efficiency is not being utilised well in these areas.
