Home > Wanted > 3.1 CW&P
Nick
Member #: 154
Midlands
After a 3.1 while my engine is apart. anyone got one nice and cheap please :)
Dangerous
Member #: 417
gotta 3.21
Nick
Member #: 154
Midlands
cool, i might just take you up on that if i cant get a 3.1 in time dude. Will let you know.
Cheers, Nick :)
Didn't Iain offer a 998 A+ recently? All these have 3.1 diff's don't they?
Dangerous
Member #: 417
I think it depends on whether 10's o 12's were fitted
it was e reg, on 12's. so whatever that makes it *happy*
your welcome to it!
Pretty sure that's a 3.1 then!
2.9's were on the 10" ones.
nutter driver
Member #: 47
Not very sunny swanage
i was under the impression that 998's mostly had 3.44s???
Early (A series) 998's had 3.444 diffs, except some vans/pickups which had 3.76. The changes came with the A+ stuff, the early A+ engined cars from approx 1980-ish to 1984, fitted with 10" wheels had the 2.9:1 diff. The 12" wheeled cars from 1984 onwards had 3.105 diff ratio.
Metro turbos as most of you know were 3.21, as far as I know all the carb and SPI 90's Coopers were 3.105, until the TPI's came along in '97 with the 2.76 diff ratio.
Only thing to be aware of when changing to higher (lower number) diff ratios is that on some boxes the mainshaft bearing retainer may need its bore machining larger to accept the corresponding larger diameter diff pinion gear.
Ben H
Member #: 184
Melton Mowbray, Pie Country
I have a feeling that a few 998 A+ engines came with the 3.444. I think, and I could be wrong, that the racing green and the flame red had the 3.44 in an attempt to make them a bit more sporty.
http://www.twin-turbo.co.uk
Nick
Member #: 154
Midlands
cheers for the info dudes, and thanks for the offer of the engine iain, pity i cant get up to you anytime soon to collect unfortunately.
have given away 2 998 engines recently aswell...bugger!
Edited by Nick on 14th Sep, 2005.
