Home > For Sale > 1993 mini mayfair turbo project job lot £1800 ono
minimenzies
Member #: 10628
Colchester, Essex
For sale
1993 mini rover mayfair SORN
Turbo project job lot
I have owned the car for a few years and have done most of the work on it myself. It’s a fairly solid base for a good car. When it was on the road it was very reliable and fun to drive. Used it to do London to Brighton and a couple brands hatch mini days and a few other shows but used it daily for a while but due to going to uni its has sat. Then I’ve started to collect everything for a turbo conversion. 90% of the parts are there. Its down to the final few decisions like cam and fueling to decide. I will try to list all the bit that will come with it. I am selling up all my mini bits as I’ve changed interests in cars for now anyway.
-2x 998cc engines. Both out the car.1 has been pocketed for the 12g295 head. 1 for spares like pistons etc from memory its now a 1019cc with the head and pockets. Compression is 8.25-1 perfect safe margin for decent amount of boost. Balanced crank and flywheel.
-Good condition GT1752 turbo from a breakers (A grade)
-Saab down pipe
-Braided oil feeds from block and “t” piece
-Metro turbo plenum
-Metro turbo dizzy
-Turbo high vol fuel pump
-Fuel reg with return
-Duplex vernier timing chain
-Kent cam duplex timing kit
-The start of a mani for the turbo with out bulkhead mods
-New water pump
-New cooler running spark plug NGK
-New mini spares water hoses
-Std 998cc carb
-Boost and temp gauges
-Brand new ali rad and slim leccy fan
-2 x gear selectors 1 lightened the other std
That is most of the engine bits from which I can remember. The engine is out for a rebuke and to mock up the mani.
As for the shell its had a brand new front a few years ago which was sealed and sprayed new scuttle corners and a new A panel the drivers side sill need replacing which is really easy was going to fix it before the sale but have been doing other projects. I have done a couple minis now and know all the parts that go wrong and rust. The shell is in good condition just needs cleaning up and sorting.
From the pictures you can tell
-New front
-New A panel
-New scuttle corners
-Needs a spray job (I wasn’t bother about it to be fair)
-Basic interior
- Pressed van grill
-De/bumpered
-Removable boot and bonnet
-Mk2 lights
-Group 5 arches
-Sportex exhaust
-Front a rear subframe in good condition
-The door bottoms need attention
-Rear corners or valance need attention and they’ve cracked when coming of a curb
-5x weller wheels 10x6 with two brand new falkens and 2 camacs
-Tubbed arches
Couple spare steels Two creates of spares including lcb, blower, servos and fans and spare lights etc will come with it.
Price £1800 ono make me an offer want it gone fairly soon for the space. But I will be sad to see it go been reluctant to sell but needs must.
Here is a link to photos and build thread from a while ago can't find the one that was on here i think it was a bit more detailed.
http://www.theminiforum.co.uk/forums/topic...998-gt17-turbo/
http://s1295.photobucket.com/user/Nic_Menz...w=recent&page=1
Located in Kelvedon near Colchester
Mob: 07900154000
Menzies.nic@gmail.com
Edited by minimenzies on 2nd May, 2016.
D4VE
Member #: 10749
lowestoft suffolk
Good luck on sale, looks a good project
BUT if ya decide to split i call first dibs on the wellers!!!
Nothing gets past Dave lol
Barrieri
Member #: 11231
If you decide to sell the turbo setup I'm interested
