Home > Help Needed / General Tech Chat > T -ing into mega jolt for boost gauge
Men , am i ok to tap into the magajolt pipe for a boost gauge, mine on the stack has stopped working so was going to plum a normal gauge in for the moment , it will hopfuly be mounted a few inches away from the mega jolt unit in the car
That's how I have been doing it mate.
Seems to be ok.
Nice one , thanks.
Same here with shaunas, no problem at all
jonny f
Member #: 9894
Dorking
Same here, way i see is they're both dead ends so shouldn't see pressure loss.
Unless i'm mistaken!
metroturbo
Member #: 989
North Yorkshire
Ive done the same without any issues. It also means that if the line to the megajolt were to split or come off you would be able to see it on the pressure gauge.
