| Home > Help Needed / General Tech Chat > Mechanical pump and auxiliary pump | |||||||
18th Aug, 2016 at 08:59:43pm
Hi
My build thread..
18th Aug, 2016 at 09:57:20pm
The impellor will only spin when the pulley is turning, with the engine off you'll barely get anything past it On 20th Oct, 2015 Tom Fenton said:
19th Aug, 2016 at 05:50:59am
I was thinking that nick.
My build thread..
19th Aug, 2016 at 05:53:11am
As far as I can guess yeah, although you can configure the main electric pump to run on after shut down so need for the aux one On 20th Oct, 2015 Tom Fenton said:
19th Aug, 2016 at 05:56:37am
Yes that is true. So auxiliary pump is a complete waste if time lol.
My build thread..
19th Aug, 2016 at 06:02:27am
There should be some movement around the a series water pump because ifs not in a very good housing a fair bit of room in thee. I could be wrong. But couldn't you just rig up a small rad and cooling system just for the turbo? |
19th Aug, 2016 at 07:18:55am
Rubbish! If the impellor wasn't a good fit then the pump wouldn't move any water it would just be a shitty propellor.
19th Aug, 2016 at 07:32:04am
Some pumps are just shitty propellers. |
177 Posts Member #: 10990 Advanced Member Hornsea |
19th Aug, 2016 at 07:54:50am
Josh, I had another pump rigged up coming off the heater take off then going through a small radiator before going through the turbo then finishing off going into a sandwich plate on the stat housing and this worked well on a timer relay once I turned the engine off. I have a temp sender in line after the turbo which did show the temp drop so there was getting some flow. But because the pipe from heater take off loops up a little higher than the side mounted radiator it sometimes was prone to air locking once the engine stopped pumping.
19th Aug, 2016 at 09:49:15am
Hmm
My build thread..
19th Aug, 2016 at 04:35:38pm
The standard water pump is a very crude centrifugal pump.
19th Aug, 2016 at 07:40:33pm
Ok
My build thread..
