Home > 998cc > Pistons and compression ratio
steve2016
Member #: 11403
Are stock flat top pistons OK to use on a turbo build with 12psi max boost ?
Also what compression ratio is safe for 12psi area? I have a unskimmed 295 head that needs a rebuild and light surface skim would that combined with flat top pistons be OK?
Thanks
Yes, along with an intercooler that's fine, 10psi is safe with no intercooler.
steve2016
Member #: 11403
What compression ratio would you recommend for that psi? I have a Suzuki swift intercooler that I was going to use
I wouldn't go above 9:1 for any a-series turbo with a steel head.
