Home > For Sale > New Pistons 1275 +0.040" 6cc Graham Russell / Calver ST
Brand new never used, only opened the box, one ring pack and a one pin.
Info from the website.
http://www.calverst.com/webshop/engine/cst...perior-quality/
Manufactured from a far superior aluminium than most high performance pistons, it contains a much higher silicon content. Using advanced heat treatments, a more heat-stable piston is created. This dramatically reduces expansion under combustion/running conditions. Consequently lower piston to bore clearances are required maximising piston stability in the bore and therefore better piston ring sealing. These pistons are manufactured for race use so are more than adequate for any application allowing up to 13.5:1 CR to be used (with suitably altered distributor advance curve). Also suitable for turbo applications. 6.5cc dish. Sets come complete with piston rings and standard 0.812" diameter wrist pins. Pin to crown height is 1.5276" as per A+ high compression pistons. Weight including rings and pin 371 grams each.
Cost £200 posted.
Bargain for somebody, I bought a set for my 1380 n/a and look to be very well made, although on rods unfitted to the engine yet.
I've used them in my small bore current build and they have been great
Ok there have been some developments so they are no longer for sale!
