| Home > Help Needed / General Tech Chat > Little or No Boost | |||||||
27 Posts Member #: 11442 Member Hull |
16th Sep, 2016 at 04:21:46pm
Hi All,
16th Sep, 2016 at 06:44:49pm
Is the actual wastegate free to move? With the actuator disconnected it should just flap about freely. I think it is either a sticking wastegate, or actuator. |
16th Sep, 2016 at 06:55:49pm
No I have tested the actuator with a pump and it moves at 4psi ish. And if I disconnect the rod I can move the leaver freely and I can hear it clank in the closed position when the flap meets the manifold.
23rd Sep, 2016 at 06:49:19am
all sorted now!!!!!!! |
23rd Sep, 2016 at 07:17:12am
So what was it? For folks futue reference?
23rd Sep, 2016 at 12:20:09pm
After much head scratching and tyre kicking, I think we have sorted it....... Not quite sure what it was but....We tinkered with the actuator a little more and ran it up on the rolling road and it worked. The BDD was running to lean at the top end
23rd Sep, 2016 at 01:05:33pm
Ok so fuel pressure not rising on boost due to the gasket blocking the hole from plenum to carb. You are not the first and no doubt won't be the last to suffer that fault.
24th Sep, 2016 at 03:04:57pm
Yes, I have ordered a new HD spring from Avonbar....I taxed it yesterday and went for a blast.... After a few miles I could smell a strong smell of Petrol.... On investigation I found the boot had a couple of gallon of fuel in the wheel well and it was leaking onto the road. I have a left and right had fuel tank fitted and they are linked together with a pipe one to out let.i have the fuel return going to one tank. I fitted a new hi pressure fuel pump and it is taking fuel from both tanks and retuning it to one, so it was filling up and coming out of the overflow into the boot.....so I need to fit a second return to the new right hand tank as well.....thought I would share just I case Anyone else has the same set up..
24th Sep, 2016 at 08:41:19pm
On 23rd Sep, 2016 Tom Fenton said:
Or you can pack it out with washers etc to increase the blow off pressure. Or as you say block it off somehow. 5ps, about 65p worth iirc
(leave the rubber piston in and replace the spring with 5ps) Yes i moved to the darkside |
