| Home > Companies to Avoid > Avonbar / avr Classics bad news | |||||||
461 Posts Member #: 9229 Senior Member newcastle upon tyne |
17th Sep, 2016 at 08:01:31am
Hi I never wanted to do this but earlier this year I had bother with my aldon amethyst so decided to get a high boost dizzy from Ian Hargreaves for the summer to get some use out the car once fitted we started testing the car with a phormula ks4 we had it set so no det on boost but was to retarded bottom end & could barley pull away when advanced to pull smoothly it had det on boost this was the same as my standard turbo dizzy so I called Ian said it was no good he said send it back to be checked in the mean time I got some bits & the amethyst is now working fine so asked for a refund he said there's a 20% handling charge which I agreed was fine so we're now about 3month down the line still no money returned after countless phone calls with promises of a refund I've got no part as he told me to return it so not sure where we go from here I've fb messaged him with no reply it's a joke customer service is shocking & this is my last resort I seen a guy post on his fb wall about a poor built engine & he couldn't get anything sorted iam very disappointed after all this is because the part I received in the first place was not up to the job & would of destroyed my engine if I did not have access to the phormula |
327 Posts Member #: 1145 Senior Member North Wales |
17th Sep, 2016 at 12:18:57pm
I've mentioned something similar before.
17th Sep, 2016 at 02:25:40pm
Have to say if this is true, and I've no reason to believe not, then this is really sad news. Ian of Avonbar when I first got interested in minis back in the late 90's was one of the good guys and spent time on the phone giving advice and information, we are talking pre internet days, I also bought stuff from him back then.
17th Sep, 2016 at 03:06:00pm
This is the reply via fb |
17th Sep, 2016 at 05:02:18pm
I didn't have any issues.
17th Sep, 2016 at 05:56:11pm
Ian is fine in all honesty very helpful & friendly but seems very reluctant to refund the money for my returned part & this was my last resort |
224 Posts Member #: 9987 Senior Member Amsterdam |
18th Sep, 2016 at 09:21:12am
Bad news??? Bad news is when someone dies from a heart attack or goes bankrupt.
18th Sep, 2016 at 10:46:36am
Well surely when buying a part advertising high boost distributor & it has det on boost & at 10psi may I add not the 15 i normaly run & once retarded to hold off the det you can barley pull away with the lack of advance this can't be right surely?? I ordered this with the details of the engine so should the curve not be tailored for this? |
18th Sep, 2016 at 10:46:40am
18th Sep, 2016 at 08:02:44pm
"So should the curve not be tailored for this?"
Edited by Evoderby on 18th Sep, 2016. |
18th Sep, 2016 at 08:13:56pm
I belive the distributor I received was of std turbo curve not a high boost modified item & the amethyst didn't work as the std electronic distributer has a built in amplifier & so does the amethyst so needed to be wired different with to resistors but I've changed that & bought the correct pre locked dizzy new coil & leads so the amethyst is working fine now I understand dizzys aren't perfect but buying a product advertised for the job it can't do is false advertising & I pre talked this over with Ian & he said it would be fine for my needs |
