Home > Help Needed / General Tech Chat > Actuator adjustment GT17
ian2000t
Member #: 2764
Halesowen
I had to relocate the actuator, and run it the opposite direction (cut and welded the wastegate lever).
But, I don't know how much preload the actuator is under, and what psi it will activate at.
What's the easiest way to adjust/set this, without just flooring it and watching the boost gauge (bad idea, obviously)?
1994 Mini Mayfair, 1330, Mspd Ph2 cam, Benross turbo head, 9:1, GT1752, TT Intercooler, MegaJolt, BMW M3 leather seats.
Can you get an airline with a gauge to it ?
Phil.
Set it with an airline and gauge, it only just needs to start to move at your desired boost, if in doubt leave it on the loose side, you can always tweak it up a bit at a time if needed.
ian2000t
Member #: 2764
Halesowen
Good idea! Should be able to do that, thanks guys!
