| Home > Introduce Yourself > new member turbo fitting issues | |||||||
3 Posts Member #: 11448 Junior Member |
22nd Sep, 2016 at 09:18:42am
hi there im fitting a metro turbo engine and the turbo with mainfold i have is incomplete, theres no feed or return pipes, i see people have modified a fuel pump blank but are there specific parts i can buy? also does anyone have pictures pf the rear of the block with turbo fitted to show me what im missing?
22nd Sep, 2016 at 09:30:28am
You can get a new oil feed pipe from minispares. I think its the goodridge one, or you can a local hydarulics place to make one up for you. The return you just need a 90 degree oil resistant hose. You can get the return plate that goes on the back of the block from smiffys bits if you want a shiny one. And i think DSN retrosport do one but dont quote me on that. |
22nd Sep, 2016 at 09:33:39am
http://minispares.com/product/Classic/Engi...k%20to%20search
22nd Sep, 2016 at 09:40:03am
was a bit sceptical to whether id get a reply, but without a doubt youve saved me loads of time and money thank you very much hazpalmer |
22nd Sep, 2016 at 09:49:48am
On 22nd Sep, 2016 belcher97444 said:
was a bit sceptical to whether id get a reply, but without a doubt youve saved me loads of time and money thank you very much hazpalmer No worries that oil feed pipe from mini spares is a bit costly. So I'd try a local form. If you search on here you can find what size/threads you need. |
22nd Sep, 2016 at 09:51:07am
A picture of what you have will help. For example have you got the turbo half of the oil drain casting still attached?
21st Mar, 2017 at 09:32:41pm
Welcome to TM I have started posting on Instagram also my name on there is turbomk1golf
