Home > Help Needed / General Tech Chat > Cooper s conrods
giannoutsos
Member #: 8952
Athens Greece
Good morning all,
After finding out that that my worked crankshaft has a crack in it so obviously I can't use it, I bought a brand new one from a friend that has smaller big ends so I need cooper s con rods.
So which aftermarket con rods are good from the cheaper ones on eBay?
Does anyone have a set for sale?
Thanks in advance
Specialist components for something reasonably priced, and good quality. Wouldn't bother with eBay, unless you know the source. False economy to risk it.
Edited by minimole23 on 25th Sep, 2016.
slater
Member #: 1291
Suffolk / Birmingham
The eBay rods all come from the same source as far as I can tell. Somone did do a weight comparison and they were heavier than SC but more than good enough for anything but an all out race motor. I will be using a set in my next engine for sure.
Well the eBay rods from Williams come in the same box as SC's...... and have genuine arp bolts in a packet.
giannoutsos
Member #: 8952
Athens Greece
Thanks for the answers,
I agree with Graham most of them look the same, should come from the same supplier.
I would love to hear from people that have used them.
i have a set of Arrow, new unused 10 years old still in the box from Arrow,
with S big ends,
I know of a few sets fitted to mini se7en race engines, been going strong for a couple of seasons now and they regularly spin to 9k on track.
giannoutsos
Member #: 8952
Athens Greece
Which one are you talking about Matty, can you be more specific please.
The Williams 6" rods without bolts are 532g
I know a Williams set is, and the set that came out were of another make, I can't remember exactly what make they were now though, they were only removed due to a spun bearing and heat discolouration on the BE.
slater
Member #: 1291
Im pretty sure they all originate from the same place. Someone was advertising on ebay not long ago to make them to your spec. (size wise at least) im pretty sure you just send off your sizes to china and they come back with your name lasered on the side but are all made in the same place out of the same stuff!
tadge44
Member #: 2500
Buckinghamshire
MG Midget rods are the right big end size and pretty tough - if you can find them.
The ones in my car see 7k + and 17psi and so far so good.
giannoutsos
Member #: 8952
Athens Greece
Thanks for all the answers, Slater I agree with you
I believe the spun bearing may be the real issues with these rods, but id expect any decent engine builder would check the bearing housing for size and roundness first. Turbodave16v linked to a thread on another forum and one mans findings highlighted the differences for your money, but it involved the possibility of a spun big end
giannoutsos
Member #: 8952
Athens Greece
Do you have the link Sprocket?
Would make an interesting read.
Thanks
Edited by giannoutsos on 26th Sep, 2016.
The spun bearing on the engine I stripped, was down to 15mins of racing with no oil pressure, and 4thou clearance on the mains. 😂 you could literally rattle the crank...made good power though! (not my work).
I think the are essentially the same rods with different names, but these two sets were slightly different, very subtle but you could tell they were made differently due to a few of the profiles and surface finish on the non machined surfaces.
Thanks
Interestingly, most people seem to suggest that "cheap Chinese" means 'poor quality'. I'd say that has been confirmed to be true at the very least regarding the dimensional accuracy. I'd be tempted if it was for something as simple as a longer rod or a Cooper S big end for a stroked 1430 rather than a lighter rod for a balls out screamer.........
Considering such a 'heavy' rod as these "cheep Chinese" in a balls out screamer, you really aught to re assess your decision making paradigm before anything else. I said it before, and I'll say it again; That is not to say these cheap Chinese rods don't work. If you have a valid justification to use such 'heavy' rods, by all means do so, but not just because it's fashionable.
Measure measure measure..................
On 21st Jan, 2014 TurboDave16V said:
I was a bit bored, so looked on interwebs for maxpseeding rod info.
http://www.mgexp.com/phorum/read.php?41,1826191
http://forums.mg-rover.org/showthread.php?t=406766
Both of these links contain interesting information; the MGExperience site talks about billet machined rods made in England that were embarassing quality with the BE being interpolated on a CNC instead of finish honed to size!!!! WTF!!!!
The MGRover site mentions Dave Andrews (respected K-series tuner) uses the maxpseeding rods, and that initially the rods had a few little issues that made them "not as good as they could have been", but with feedback from DA, resulted in a modifed design that no-one has any reported failures on...
I'd say these could be worth a sniff. The interesting (or should that be blatantly obvious) thing is that all ebay, SC, and "others" rods all look the same.
I can beat that haha. Center main bearing failure..... pistons were touching the head *Clapping* I drove that home and oil pressure was still acceptable. Had a little bit of a knock though *Rofl!*
Come to think about it, there's a similar situation going on in the oak furniture market. It all looks the same, is made of Oak and comes from China *Rofl!*
You do of course mean " very small pieces of oak" glued together,lol *happy**happy*
They look ok and some are better than others....... Like most things Chinese...... Same Shit Different Day
jonny f
Member #: 9894
Dorking
Maxspeedingrods seem to make most of them by the looks of it.
Always see them on eBay.
http://www.maxspeedingrods.co.uk/h-beam-co...in-conrods.html
Forged my fucking arse. and that's not an offer ,lol
carl
carl why do you say that?
As a side note, I would guess most of us wouldn't be posting on here if it wasn't for China's IT manufacturing...
I was very sceptical at first with these rods, and how the tolerances would be. I had the rebush the Little ends for 998 pins, and the machining was cock bollock on, all round and better than the Sainz rods we used to build engines and these are expensive rods!
Thanks
