| Home > Help Needed / General Tech Chat > New built engine blue smoke for second time | |||||||
27 Posts Member #: 11442 Member Hull |
2nd Oct, 2016 at 06:22:44pm
Hi All,
2nd Oct, 2016 at 08:18:32pm
Leak down test? To check the rings. I run a supercharger and I don't care the TB is on the wrong side.
2nd Oct, 2016 at 10:12:14pm
Been thinking.....could it have a slightly bent conrod? Number 4's cylinder has a compression of 165 psi where the others are 170. It was fully rebuilt last year with omega pistons and after 200miles it was smoking..... The engine builder took responsibility and rebuilt it with new omega pistons and AP head bolts and AP bottom end. I wonder if it has a slightly bent conrod??? These have not been replaced... It may explain the low compression and kickback??? Possibly
3rd Oct, 2016 at 05:15:25am
Has the engine been properly run in?
Yes i moved to the darkside |
3rd Oct, 2016 at 07:07:51am
The engine was run in on the rolling road, but I had driven it normally, not revving it more than 3-3.5k. oil is 10w/50 and it is showing 100 when cold and drops to around 40-50 warm (at tick over) it has only done 120 miles this time last time 280. the last time the oil rings had worn, but a component in the gear box has failed and there was metal in the oil, Guessworks have rebuilt it this time. the symptoms are exactly the same, starts and runs fine.... then one day smoke and kickback on starting. when it fires it runs fine, pulls fine but guffs smoke. ?????
3rd Oct, 2016 at 07:30:11am
as above is this a turbo lump
3rd Oct, 2016 at 07:32:10am
also 10w 40 is maybe a bit thin, 20w 50 gets my vote.
3rd Oct, 2016 at 08:46:37am
Yes Metro Turbo, o.6 bar boost, would 100psi of oil pressure that cause the problems i am having???? |
3rd Oct, 2016 at 08:59:58am
I bought the engine second hand 18month ago, the engine was dropped of straight to the engine builders august 2015 and I got it back October 2015 after a full rebuild. it was set up on the rolling road it lasted 280miles and started to guff blue smoke when starting and setting off. it went back under warranty, we found a bearing in the gearbox had failed and aluminium and bearing was floating around in the oil, the oil rings had worn out and the piston skirts scored. the engine was also kicking back when we tried to start it. I sent the gearbox to Guessworks for a full rebuild and crosspin diff while the engine was rebuilt again. The engine builder has ran the engine in and set it the boost, fuel pressure and timing. it has been on the rollers for nearly 40Hours..... I have driven it on the road at normal road speeds for a further 120miles, then the exact same problem as last time. so I am looking for things they might of over looked..... Pete |
3rd Oct, 2016 at 09:55:54am
What is the ignition system, it should not be kicking back or running on.
3rd Oct, 2016 at 11:07:25am
New Metro Turbo Electronic distributor and coil..... |
3rd Oct, 2016 at 05:56:06pm
If it was rings you'd likely get constant smoke and high crankcase compression. 5psi difference on one cylinder is nowt to worry about.
3rd Oct, 2016 at 08:11:41pm
Going for a leak down test tomorrow......will let you know.... |
4th Oct, 2016 at 07:44:27am
thinking out loud and listing stuff to check/try....
4th Oct, 2016 at 09:49:36am
When I first start it the engine kicks back for a couple of rotations then starts.... No smoke...leave it ticking over for a few minuets and blip the throttle puffs of smoke from the exhaust....I have asked about the oil pressure and was told 100psi is fine when cold and when it is warm it drops to 40-50 on tick over and 80ish driving. .?? |
4th Oct, 2016 at 11:13:45am
still not mentioned if this is turbo'd or not,
4th Oct, 2016 at 11:17:28am
as a rule with turbo's you want 50 PSI max, normaly you'll see about 20 at idle. ok you might see 60-70 cold but much more than that wants looking into.
4th Oct, 2016 at 12:49:53pm
I concur with Joe.
4th Oct, 2016 at 02:13:10pm
Yes Sorry, Metro Turbo...... The engine builder said that he thought the weights in the dizzy were a bit light???? I have checked with the supplier and they tell me it is the right application? I ran it at the weekend with the rocker box off and there was no heavy flow of oil. What is the effect of high oil pressure when cold? the engine guy did not seem concerned when I pointed it out he said as the valve opens when it warms up it will go to normal?
4th Oct, 2016 at 03:08:54pm
hmmmmm,
4th Oct, 2016 at 03:52:04pm
That's interesting. ...it is 100 at first. ..then about 5 minutes or so it starts to drop. It tick over its 40-45 and rises to 70-80 at speed when warm. I wonder if it pushing oil past the Turbo seals when warm? Which would explain the blue smoke. It only smokes when it warms up. Nothing for the first 10 minutes or so. ? |
4th Oct, 2016 at 05:32:37pm
FFS,
4th Oct, 2016 at 07:44:49pm
The car is with the engine shop, I will call in tomorrow and have a word and give you an update......still does not explain the sudden coincidental kickback???
5th Oct, 2016 at 07:52:34pm
On 3rd Oct, 2016 peterh said:
Yes Metro Turbo, o.6 bar boost, would 100psi of oil pressure that cause the problems i am having???? absolutely, high pressure is not needed, constant pressure is Edited by Brett on 5th Oct, 2016. Yes i moved to the darkside |
6th Oct, 2016 at 11:02:13am
you want oil flow not oil pressure
