Home > Help Needed / General Tech Chat > Silicone Brake & Clutch Fluid
vespaboi
Member #: 11303
Hello Gents
Anyone here have used DOT5 Silicone Brake & Clutch Fluid??? Is it good or not???
I'm feting all NEW staff from the brake system on my MK2 and one friend told me about the Silicon Fluid... There is any vantage using this?
Found this 2 on ebay:
http://www.ebay.co.uk/itm/111931577032?_tr...K%3AMEBIDX%3AIT
http://www.ebay.co.uk/itm/321783476691?_tr...K%3AMEBIDX%3AIT
Any recommendation???
Best Regards,
Ricardo Santos
Advantage - it doesn't strip you paint and has a high temp resistance.
Disadvantage - Fook me it's expensive.
Both are horrible to deal with IMO
h4887
Member #: 2404
Braintree, Essex
No brake manufacturer recommends silicone. There used to be an article on the AP Racing web site listing all the reasons to avoid it - don't know if it's still there
Geoff
I've never used it...but never heard any good reports about it either.
tadge44
Member #: 2500
Buckinghamshire
My A35 has used it in both brakes and clutch with no problems at all - even on track. Not changed in 10 years !
However I now use Dot 5.1 and change it very year in my other cars, because silicone is a sod to bleed free of air mainly because it is more viscous.
you change brake fluid every year ??
That's a bit mental
tadge44
Member #: 2500
Buckinghamshire
If the car is used on track then definitely change it every year.
Friends who race change it every meeting for consistent pedal response. I do it to keep moisture and corrosion at bay.
May well be anal but it can do no harm,.
WOW! they must have sensitive footsies? Do they change the disks and pads too?
On 7th Oct, 2016 tadge44 said:
Friends who race change it every meeting for consistent pedal response. .
t3gav
Member #: 229
Gavin@minispares.com
kent
Just a heads up, AP will not warranty any classic Mini component that uses silicone fluid, it degrades the seals. That's why I now stock the Millers racing fluid as it's DOT4 based.
tadge44
Member #: 2500
Buckinghamshire
Wil, with 560hp and 900kg they need all the help they can get. The brakes get very hot indeed so there is concern that it may be getting affected. 13" discs and cooling ducts.
AP may be right in protecting themselves but I have had no problems with seals, as above.
Not trying to encourage anyone to do anything, just relating my own experience.
Sounds like fun!
It one of those things, if you think it works keep doing it. Between runs everyone in my class at hillclimbs gets heat guns out and sureform blocks and buckets of soapy water and make their tyres look like new. I sit on mine and have a brew.
I don't go any slower!
jamiestevenbell
Member #: 9941
Derby
I've ran silicone brake fluid in my mini for 6 years and never had a problem! Amd have done a fair amount of trackdays issue free!
