| Home > Companies to Avoid > INNOVATE | |||||||
307 Posts Member #: 11231 Senior Member |
17th Oct, 2016 at 06:47:15pm
Hi guys, around 6 months ago I bought two wideband Innovate MTX-L sensors. Everything seemed fine since then. Last weekend I was driving around in my Mini and one of the sensors all of a sudden began reading E8. I turned off the engine and after some minutes started again. The sensor read the AFR normally, but after around 2 minutes began reading E8 again.
17th Oct, 2016 at 08:00:01pm
You haven't given them a great deal of time to respond to the issue |
17th Oct, 2016 at 08:00:51pm
Good luck contacting them.
17th Oct, 2016 at 08:01:44pm
edit: double post Edited by Rob Gavin on 17th Oct, 2016. |
17th Oct, 2016 at 08:03:41pm
Actually they responded this hour, but no satisfaction whatsoever. The reseller sent me to Innovate with the complaint and Innovate told me to deal with the reseller :@ |
33 Posts Member #: 9867 Member |
17th Oct, 2016 at 08:42:44pm
I have the same issue at the moment.
17th Oct, 2016 at 09:13:13pm
In my case I don't think it can be the sensor, because even when the car has not yet been started, it says E8. |
17th Oct, 2016 at 11:14:03pm
Sale of goods act, google it, but I think I'm right in saying that your contract is with whom you paid the money to buy it, and the responsibility to sort it (and desk with the manufacturer if needed) lies with them.
18th Oct, 2016 at 04:36:08am
Now I'm another one in the list mate. Not only the products didn't last long but also the aftersales service is really below expectation levels. |
18th Oct, 2016 at 07:24:29am
i love my innovate stuff its mega Medusa + injection = too much torque for the dyno ..https://youtu.be/qg5o0_tJxYM |
18th Oct, 2016 at 07:54:21am
Mine is an LSU 4.9 |
18th Oct, 2016 at 03:58:35pm
Did you check that the gauge firmware was set to the 4.9 sensor ? Saul Bellow - "A great deal of intelligence can be invested in ignorance when the need for illusion is deep."
18th Oct, 2016 at 05:32:48pm
The sensor was running fine it just stopped all of a sudden. Also they told me to update the firmware and I did, but no luck :/ |
18th Oct, 2016 at 05:58:43pm
On 17th Oct, 2016 Tom Fenton said:
Aside from that I've never heard anyone with a positive thing to say about Innovate stuff! I'd be a little bit more conservative and say I've rarely heard anyone with anything positive to say (rather than never heard) but, yes, their latest stuff, esp. the series two contollers and with 4.9 does seem to be crap. I gave up on Innovate years ago after the first one failed and someone else on this forum sent me another failed one to have a look at. No experience of AEM but TechEdge is good but expensive, 14point7 is the best IMHO but very DIY (which kind of goes with any Megasquirt setup). The Innovate stuff seems to kill the LSUs (sensors) but they will still work with 14point7 even after Innovate has killed them. In your situation how have you actually got the LSUs installed ? It's quite critical in a siamese turbo setup if you are using two. Only the 14point7 setup I use can actually read the temperature of the LSU pump cell so can tell me if I'm killing them. Schrödinger's cat - so which one am I ??? |
18th Oct, 2016 at 06:02:37pm
On 17th Oct, 2016 Smackfiend said:
is saying the sensor could be getting to hot so to fit an lambda extender, they're only £6 so I'll give that a go. And that was my point above, why buy a controller that can't read the temperature ? There are two issues with a turbo setup, temperature and pressure. If you don't know what they are the readings could be crap even before the LSU fails. Schrödinger's cat - so which one am I ??? |
18th Oct, 2016 at 06:04:38pm
Shaunas Innovate Lc2 had a low power error, had a quick look at all connections etc and for corrosion on the fusebox and didn't see any. Never ended up getting to the bottom of it. Has anybody else had that come up before? On 26th Jan, 2012 Tom Fenton said:
18th Oct, 2016 at 06:55:30pm
Hi Rod, I built my manifold to have two sampling pipes 4mm ID routed to two chambers in the downpipe. The sensors are attached in these chambers. So this way I'm exposing the sensors to a pressure downstream of the turbo, but having it reading the AFR of the respective runner. Credits to Paul S for the setup. Unfortunately my budget haven't yet allowed me to buy EGT sensors, although I wish to.
18th Oct, 2016 at 08:48:02pm
Your sample system seems pretty similar to mine, and Paul's and others.
21st Oct, 2016 at 04:52:34pm
Hi Rod S, what 14point7 wideband do you have ? Today I was browsing their webpage and I noticed that their controllers only cost between 75 USD and 100 USD, which is basically the cost of an LSU4.9 sensor. So I recon if a 14point7 controller still operates an LSU4.9 after Innovate has killed it, its better to actually buy a controller from 14point7 instead of a sensor for my Innovate XD I can't keep on buying sensor for every thirty hours of testing :p |
23rd Oct, 2016 at 10:22:17am
I use the SLC-OEM modules. I must point out though that they are NOT a standalone controller, they are a controller module that basically has to be plugged into a carrier board to provide the power and output interface(s). I use them because (a) they have a digital output which is potentially a lot more accurate than the usual 0-5V analogue and (b) the digital output includes the LSU cell temperature. The digital output goes to one of Jean's IOx's which is the interface between the MS2 and a bank of LED displays.
23rd Oct, 2016 at 10:37:28am
I'm not a fan of inovate stuff, I had an LC1 which gave no end of trouble, the programable outputs would go haywire all the time and output crap to the ecu,
23rd Oct, 2016 at 11:48:43am
Thanks a lot Rod S, that is what I will do actually. Thanks also Joe C. |
29th Oct, 2016 at 05:17:00pm
Any news?
29th Oct, 2016 at 06:01:21pm
Hey mate, yet still the same. I also tried to update the firmware but no luck. |
(but it is all lm1 first gen stuff.)
