Home > Help Needed / General Tech Chat > Ph 4 cam?
Rammie2000
Member #: 10190
belgium
Hi. So i removed a cam from a 998 engine which is clearly reground. Its stamped ph4 but have no idea where it came from. Anny ideas? Or does anyone can predict me how it will run? Lobes are thiner and a bit lower compared to a standard version of the same cam ( see pic's )
Thanks in advance.
Edited by Rammie2000 on 30th Oct, 2016.
Rammie2000
Member #: 10190
belgium
Morspeed I reckon,
I know thwy did phase 2&3 cams, the phase 3 being a trackday cam, presumably phase 4 was a race cam of 290-300 degrees.
Rammie2000
Member #: 10190
belgium
Would not be very drivable on the road then? Tought on putting it into my 998 with 1275 head high compression ( 13 to 1) twin carb.
Deffo a morspeed that mate
I had a phs3 and it was a great cam. Id say it would be pretty wild and think anything under 4 grand will be pretty shit.
Edited by MikeRace on 31st Oct, 2016.
Rammie2000
Member #: 10190
belgium
So now i have a powerband between 2800 and 6800. Would mean my power band would be between 4000 and 6800 then? Would it make more power then the metro cam thats in there now?
It may make a bit more power but will move it into areas of the rev range you may never use.
What are you doing with the car? Daily or Track?
no idea without more details on your spec,
but generally a full race cam is going to be shit in a standardish engine, you'll want long runners and a good head, and high compression to make the most of it.
Like Joe says your pissing into the wind a bit without the figures. Personally I wouldnt use it unless its going on something pretty wild.
also from the pics it looks like it been kept up a badgers arse LOL
Rammie2000
Member #: 10190
belgium
The 998 is high compression ( 13 to 1) 3.1 diff 1275 flown big valve head from a metro. Electronic ignition twin 1.25 carbs thats about it. I use it maybe 7 times a year to do a 200 km run in it tops or when the fiat brakes down. Come to England in it once a year top. Thats it. Done maybe 500 km this year. Do sometimes pull a trailer made out of a mine end with it.
Rammie2000
Member #: 10190
belgium
Comes out of an engine keith calver build and the man he build it for then stored the half engine on the floor of a damp garage 7 levels benath sea level for 4 years... who knows what eighter the builder or the buyer did with it in those 4 years... hahaha
