| Home > Help Needed / General Tech Chat > calculating top speed , drop gears , cwp etc | |||||||
1st Nov, 2016 at 11:12:54pm
Right guys the mini tops out around 94mph , that's shown on the rollers , gps speedo and that's the speed it did over the line at the drag strip on the limiter lol.
Edited by cossierick on 1st Nov, 2016. |
2nd Nov, 2016 at 12:59:28am
Tyres. Not all 165/70s will have the same circumference. I suspect you have them on quite wide rims which will reduce circumference slightly and gear you down |
2nd Nov, 2016 at 07:40:25am
Really 12mph difference ! If i put 13" wheel in the calculator it alters the too speed 2mph !
2nd Nov, 2016 at 07:49:22am
What I would suggest is find a nice flat piece of tarmac/road/drive (whatever), put a chalk mark on one of the front tyres pointing at the ground and a corresponding mark on the ground and push it in a dead straight line for, say, ten revolutions of the wheel until the chalk mark is pointing at the ground again and measure the actual distance travelled.
Edited by Rod S on 2nd Nov, 2016. Schrödinger's cat - so which one am I ??? |
![]() 690 Posts Member #: 9962 Post Whore |
2nd Nov, 2016 at 08:02:21am
Using a 1:1 4th gear, 1:1 drops, 3.76 FD, 1540mm tyre circ and 7000 rpm (you don't mention what rpm the limiter is supposed to be set at) I get 107 mph.
Edited by Aubrey_Boy on 2nd Nov, 2016. |
2nd Nov, 2016 at 08:25:03am
Why did you choose that cwp?
2nd Nov, 2016 at 08:33:44am
Rick, have a look at the graph from Johns, what were the engine revs showing on the limiter?
2nd Nov, 2016 at 08:46:50am
Ha thanks jonny , it was in the box years ago when i got it.
Edited by cossierick on 2nd Nov, 2016. |
2nd Nov, 2016 at 10:57:12am
Shouldn't matter if the other two are the same Rick. If something is worth doing, it's worth doing half of. |
2nd Nov, 2016 at 11:05:07am
It sounds like you have a 4.2 diff in there to me Rick but if you have counted the teeth on the pinion then bugger knows! If something is worth doing, it's worth doing half of. |
2nd Nov, 2016 at 01:58:02pm
strange one; given the fixed info from the hardware, I'd have to wonder if the rev limiter is accurate. Have you any way of checking the revs independently of the limiter? data logging or something perhaps give you another indication? The info would suggest your topping out at 6500rpm which I think you'd have been aware of in reality |
2nd Nov, 2016 at 03:19:04pm
a couple of thoughts,
2nd Nov, 2016 at 06:50:39pm
I haven't done a tyre rolling circumference yet but will do, il also check the graph from the rolling road.
2nd Nov, 2016 at 08:13:50pm
only 94 mph, Rubarb!!, I have a timing ticket form York raceway showing just over 90mph for the DON in second gear, so that's at least 400 mph in top.lol
2nd Nov, 2016 at 09:18:10pm
Yes but you are THE carl austin !!! Lol |
2nd Nov, 2016 at 09:44:41pm
You have 1.1x drops, geuss works and your info gives 95mph at 7200rpm change drops out for some 1.1's or under driven drops Drives
2nd Nov, 2016 at 09:48:51pm
1.1364:1 22/25, jkd gear set, 3.7xx diff gives 93mph @7k Drives
2nd Nov, 2016 at 10:04:46pm
Rick mine topped out at 108 with a 3.44 diff and 1:1 drops and 165/10's 032's, guesswork's calc says 115 so there must be some variables. Crystal Sound Audio said:
2nd Nov, 2016 at 10:54:41pm
Paul are you on crack !!
2nd Nov, 2016 at 10:56:56pm
And don't you forget it ,lol
3rd Nov, 2016 at 07:53:24am
No I'm not, just had a look through the drop ratios, information given and change drops to the other set gave the speed at rpm you gave, makes sence for the low top speed you are experiencing.
3rd Nov, 2016 at 08:33:47am
he's already stated that the primary and input gear have the same no of teeth you fucknugget On 28th Aug, 2011 Kean said:
3rd Nov, 2016 at 08:39:01am
Did not see that. Drives
3rd Nov, 2016 at 11:09:57am
On 3rd Nov, 2016 Joe C said:
3rd Nov, 2016 at 11:30:15am
On 3rd Nov, 2016 Paul R said:
No I'm not, just had a look through the drop ratios, information given and change drops to the other set gave the speed at rpm you gave, makes sence for the low top speed you are experiencing. It's obviously not final drive if you have counted the teeth and worked out the ratio, gear set is highly unlikely to have a special short 4th rev limit has most likely been seen on a tach or ecu checked leaving the drops. 4th is direct drive.
