| Home > Technical Chat > Gearbox U seal | |||||||
68 Posts Member #: 596 Advanced Member |
18th Sep, 2005 at 10:39:50pm
1293cc turbo engine almost finished.... Q: The half moon oil seal that goes between box and crank doesn't seem to fit very well. When in the box it doesn't sit flush at either end. Do I need to trim it to fit or does it get compressed enough when the bolts are troqued? I noticed on an MPI engine that I have that rover seamed to have removed this seal and replace it with a curing sealant... |
19th Sep, 2005 at 12:54:49am
Personally - I trim it, such that it's 'just' a little too long. Also - add a little 'drop' of RTV onto each end for extra sealing.
19th Sep, 2005 at 07:23:36am
I'm a fan of the cut it to lengh and a dab of hightemp RTV under each end method and i've had good succes with it.
Two things are infinite: the universe and human stupidity; and I'm not sure about the the universe. |
19th Sep, 2005 at 09:00:31am
like to add trim it spot on!
19th Sep, 2005 at 12:15:46pm
Wellseal is the dogs nuts, far far better than anything else, although its a fucker to get off your hands afterwards!
19th Sep, 2005 at 12:16:58pm
I always trim them as well. They are too long from the factory. On 13th Jul, 2012 Ben H said:
19th Sep, 2005 at 01:12:16pm
I use loctite 574 (the orange flange stuff) always worked great for me, even on "skint get me outta hassle till payday with no gaskets" engines. On 28th Aug, 2011 Kean said:
