| Home > Show Us Yours! > Some gearbox pictures | |||||||
19th Sep, 2005 at 06:35:03pm
19th Sep, 2005 at 06:52:49pm
Plea for parts, I need the two long bolts that bolt the engine mount bracket up to the gearbox, pointed at by red arrows here!
19th Sep, 2005 at 09:15:04pm
Hard to tell in the pic if its just a casting mark or not.
20th Sep, 2005 at 07:40:39am
Looking good mate |
20th Sep, 2005 at 08:09:32am
On 19/09/2005 18:52:49 Dangerous said:
On the gearbox theme I was thinking earlier about gearbox to engine gasket thickness. If you just use sealer then the mesh on the transfer gears will be greater(you know what I mean).....could be why the gearbox input bearing goes
VERY bad idea. They are not designed for this, and will fail. As many US recers have experienced. On 13th Jul, 2012 Ben H said:
20th Sep, 2005 at 02:00:21pm
Nice job, got the casing bloddy clean!! -MINI CLUBMAN 1380 TURBO- |
20th Sep, 2005 at 03:00:46pm
How've you managed to trake a picture of the parts you need?
20th Sep, 2005 at 03:06:41pm
Ha ha ha see what you mean! The bolts there are only some 5/16 UNF by about 1 1/2" long, they are only in there enough to keep the bracket up together with the gearbox!
269 Posts Member #: 396 Senior Member sheffield/rotherham |
20th Sep, 2005 at 09:18:40pm
looking good tom seems to b coming along rather nicely speed is the best rush i have ever had!!!
