Home > Help Needed / General Tech Chat > Ally 4 pots for use with 7.5" discs
Aubrey_Boy
Member #: 9962
So I am looking for a set of ally 4 pots for my other project, I originally just planned to get the Minispares C-AJJ4023 but I can't remember who or where now told me... On the website they say they use a trimmed Metro pad which isn't a problem but is there a further issue with the pistons not sitting central or properly to the pad back plate?
The alternatives being the seemingly never available SC Monoblocks and KAD 4 pots
Anyone used the Minispares caliper and aware of any pad / piston alignment issues?
Also any idea if the SC or KAD 4 pots give any more or less clearance to more difficult 10" wheels like the MS Rosepetals which have less caliper clearance, I think the Minispares 4 pots fit as long as the Rosepetal spacer is retained.
Edited by Aubrey_Boy on 15th Dec, 2016.
The MS 7.5" 4 pots can be used with turned down 8.4" mini discs without spacers or with Cooper S 7.5" setup with a spacer.
I didn't have to trim the pads. Mintex 1144's.
Aubrey_Boy
Member #: 9962
Cheers, when you talk about with and without spacers are you talking about Rosepetals and the specific Rosepetal spacers?
Does the 8.4 drive flange setup not widen the track compared to a 'S' setup?
D4VE
Member #: 10749
lowestoft suffolk
Sc doing another batch in the new year
Nothing gets past Dave lol
Sorry. Spacers for the calipers. The S discs are a different offset.
