Home > Help Needed / General Tech Chat > Standard HIF44 Carb for turbo
centrisg4
Member #: 147
Just Registered!
Does anyone know if a standard HIF44 or KIF44 can be modified to run a blow through setup.
Well the HIF38 / HIF44 can be adapted, but don't know what a KIF is...
Anyone? *oh well*
AlexF2003
Member #: 80
AFRacing LTD
Newbury, Berks
hello and welcome...
never head of a kif
alex
AlexF
fab
Member #: 100
Parisien Turbo Expert
Paris' suburb
the kif is the later carb used on the post 90 rover's carb k series, it seem to be difficult to adapt on a mini, as his inlet is very different and uncommun it is also a more complicated carb,
as Dave said any hif can be converted easily, seal the dashpot face with engine sealant, reverse the butterfly seals , don't forget to use a stronger spring and the good needle, about the leaning device system you shouldn't bother with this as it's better without, I also like to pressurise the fuell using the vapors pipe, because it give a better signal to the carb.
fab
fab
Member #: 100
Paris' suburb
or why not bid on this:
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?Vie...&category=10414
AlexF2003
Member #: 80
AFRacing LTD
Newbury, Berks
Its far far easier to get a turbo HIF than to convert one, that way if you have any toubles you don't need to suspect the carb conversion itself...
Turbo a-series are tricky enough as they are with making extra work for yourself.
They can even be brought new for the ultimate in peace of mind!
alex
AlexF
1310turbo
Member #: 41
See http://www.burlen.co.uk/ for new carb
A-series power! 1972|1310|T3 turbo|Omega pistons|Cantre main strap|Orange clutch diaphragm|AP race plate|Comp pressure plate|Lightened steel flywheel|13-row oil cooler|Vernier duplex timing gear|Phase 2 Piper cam|Green air filter|Hi boost carb needle/spring|2"Stainless exhaust|3"Play mini stainless rear box|Jack Knight s/c 4spd gearbox|Jack Knight s/c drop gears|Silicon coolant hoses|Lumenition HT leads|GAZ lowered height shocks all round|Steel flip-front|Rear safety devices cage|Group 5 arches|6x12 deep dish Minilites|Surf blue/Old english white|
1310turbo
Member #: 41
