Home > Help Needed / General Tech Chat > trouble bolting gt17 to t3 manifold
c2_mad
Member #: 4215
hi guys,
trying to bolt up my new gt17 turbo to my t3 turbo manifold, that had already been adapted to fit the t2 turbo. but already ran into a snag. on the flange that mates to the manifold there is one hole, that has no space for a bolt behind it. how did you guys get around this?
cheers
Take a die grinder and make a notch.
I also rotate the turbo slightly on the manifold; which I recall helps....
c2_mad
Member #: 4215
that was my first thought... just wanted to know if somebody else had come up with a better solution that i hadnt thought of.
I was going to run a stud into the turbo and put the nut on the manifold side.
Edited by John on 9th Mar, 2017.
c2_mad
Member #: 4215
but on the manifold(t3 one) there is no place for the nut, it where one of the branches come out
You'll have to grind it to allow room as described above.
c2_mad
Member #: 4215
thanks for the help guys, went ahead and did it already. was a bit nerve wracking, scared i would grind through. all sorted now.
