Home > Technical Chat > drop gear clearance gasket thikness
fab
Member #: 100
Parisien Turbo Expert
Paris' suburb
Hi fellows that's a long while.
i'm rebuilding a 998 cooper engine (1030/hr 270/ported 12g295 11.5 cr, 3.64 dif on cooper s box) but have trubles with the drop gear clearance *tongue*
This come from the gasket thikness, I know we have already talked about this in the past but can't find the post, does a charitable mind have the compressed transfer case gasket thikness? *happy*.
cheers
fabrice
Hello Fab
graemec
Member #: 1424
Carnforth, Lancs
From memory the standard gasket is 0.032" think. I doubt it would compress by more than .001-.002 given the fixings are only torqued to 18lb/ft
fab
Member #: 100
Paris' suburb
Hi Andy, still there *tongue*; hi graemec;
Gone to mini part supplier yersterday:
-pink chippo gasket is 0.295in / 0.75mm compressed mesured with palmer
-grey genuine pocket is 0.287 in / 0.73mm GUG701608CS.
drop gear clearance is down to 0 from 8 thu..
graemec
Member #: 1424
Carnforth, Lancs
The genuine gasket is usually green?
http://minispares.com/product/Classic/Gear...k%20to%20search
I can measure one of those later.
Glad to see you're still around Fab.
Phil.
fab
Member #: 100
Paris' suburb
Thank Phil ;p
Graemec,I'm used to use the green one but the only one I found today is genuine and ok, it's a grey one in genuine convertion Gsk kit, it does allow to set the gap to 3 thu with standard shims. thi said Please mesure so we can keep somewhere the mesures, this thread is correctly intituled and will allow to find back.
Gearbox and drops complete, going one the engine set up.. I have a geuine std 544 under the bench that is tempting to build a formula junior replica engine :)
cheers
Fab
Edited by fab on 15th Apr, 2017.
Doodmeister
Member #: 149
Alberta, Canada
Hi Fab.
Minispares pink gasket in kit AJM206MS measures 0.032" if it any help to you.
fab
Member #: 100
Paris' suburb
Thanks Dod, pb solved, fitted two std shims with the grey one, and gap is spot on at 3 thu
