Home > Help Needed / General Tech Chat > MPi turbo mirage woes
Steve220
Member #: 11017
Shropshire
Hi all, looking for a bit of advice if possible.
Creating an MPi turbo with a GT17 and a mirage manifold. Did a test run of the set up on the block and head before it gets sent off for the engineering work but I've stumbled upon an issue with block clearance.
Has anyone come across this before? If so, how've you gone about it?
Regards and thanks
Steve
I'm pretty sure it was Simon (MadMK1) that had this issue. He ground some of the block away to provide clearance. Have a look through his build thread.
Phil.
Steve220
Member #: 11017
Shropshire
Hi Phil,
Thanks for getting back to me. The issue I have is the cam sensor mount and sensor itself will be in the way and I'm reluctant to grind it away if I can prevent it.
Is it actually clear or not? Cannot tell from pictures. Either relieve the block or move the turbo its as simple as that! Remember the head gasket when fitted will move it up a touch.
Are you intending to use the OEM cam sensor ?
The "mount" is just the original mechanical fuel pump mounting position, usually just blanked or used as a turbo oil return, it was just on the MPI they used that hole for the phase sensor (with a modified fuel pump lobe on the cam).
So, unless you are intending to run an ECU that needs that particular sensor along with the modified lobe on the MPI cam surely you can just remove it and fit the usual blanking plate (or turbo oil return) ? Neither of them should get in the way.
evolotion
Member #: 83
Glasgow, Scotland
as its at the retaining side of the sensor you can likely shave a lot of material and use a counter sunk screw for retention, and shave a little off the turbo, and elongate the turbo-manifold holes and rotate it slightly etcetc, all this will add up as you only need to find a couple of mm.
Denis O'Brien.
Hi Steve,
As pointed out above, try it in position with all of the gaskets in place, rotate the compressor housing into the correct position, and then see how much clearance you have.
I had to relieve the block and the compressor housing to gain a few mm of clearance.
Just don't get too carried away grinding chunks off!!!!
Steve220
Member #: 11017
Shropshire
Hi all,
Thank you for getting back to me. The inlet will be an SC 5 port system and from what they've told me, i'll need the cam sensor. I'll give it another play tomorrow with the old gaskets on to see if there's much different. The other option i thought about was to re-position the turbo flange, I know there's not a great deal of room back there, but if I have to add a small turbo box to the shell then so be it.
Use a crank sensor in there intead, much more compact
jonny f
Member #: 9894
Dorking
Could you not just use a crank sensor on the crank?
Also it doesn't look like a gt17 turbo.
Edited by jonny f on 21st Apr, 2017.
Steve220
Member #: 11017
Shropshire
What turbo size does it look like?
Looks more like a T2 or similar
What is the difference between the SC MPi and SPi set up.............. It's the same hardware is it not?
jonny f
Member #: 9894
Dorking
Gt17 has a 3 bolt round outlet to downpipe and a bolted on compressor housing.
http://m.ebay.co.uk/itm/for-Saab-9-5-9-3-2...4%257Ciid%253A1
Will
Member #: 11091
MPI block has a camshaft position sensor and no fuel pump hole
the camshaft position sensor is in a similar location to the fuel pump but higher up
standard A+ and SPI blocks are the same casting
other MPI block differences include no dizzy hole, the oil filter screws straight to the block and there's a few more sensors (ie. factory oil temp sender etc.)
I don't think that's what he was asking.....
Steve220
Member #: 11017
Shropshire
Interesting! Looks like a future purchase. Out of curiosity, how well does a GT15 work on a 1275/1293?
Not wanting to upset you but doesn't look like a mirage manifold to me either.
Steve220
Member #: 11017
Shropshire
Doesn't upset me, the manifold fits and seems to be done nicely. Just wish the turbo was sitting right! From looking back through posts it looks like it is indeed a T2. Are these much bigger than the GT17?
Edited by Steve220 on 23rd Apr, 2017.
I just attacked the block with the grinder, make sure you have a head gasket on also,
I found out after I got a new head that the old one had a lot skimmed of it which was making stuff hard also.
All things that just get in the way.
Also a manifold gasket will change stuff
head gasket, manifold gasket, turbo gasket.... that will all stack up
