Home > Help Needed / General Tech Chat > GT1752 Hot side in / out diameters
Skortchio
Member #: 10317
Basildon, Essex
As per title, does anyone know off hand (or can measure) the diameter for the hot side, both in and out on the GT1752?
Cheerios,
For the outlet, do you mean the hole where the downpipe clamps on ?
Phil.
Skortchio
Member #: 10317
Basildon, Essex
Yep, and the inlet the hole where the manifold feeds to :)
Skortchio
Member #: 10317
Basildon, Essex
Actually, scratch that. Downpipe side isn't important.
Just need the inlet diameter from the manifold.
No one has a GT1752 and a ruler?
I'll let you know this evening.
Phil.
Skortchio
Member #: 10317
Basildon, Essex
Super duper!
Cheers, fella.
The hole in the turbine housing manifold face is 40mm.
There's enough material to "square" it off to better match the Metro manifold (or similar) if you're planning on bolting it to one of them ?
Skortchio
Member #: 10317
Basildon, Essex
Smashing, cheers for that.
Will be a side mount manifold but building with potential.
Skortchio
Member #: 10317
Basildon, Essex
double post
Edited by Skortchio on 27th Apr, 2017.
