Home > Wanted > 1275cc or 1293cc turbo engine
martpaul
Member #: 668
newton aycliffe (near durham)
Hi does anybody, have one,
see im not to sure on building my own,
so i thought id ask!
cheers martin
1275 cc is a standard size
the 1293cc is only an over bore of + 20 thou
this over bore cleanes up the bores on the block making them like new!
you have fitted new pistons & rings
thats all
you can have larger over bores (ie) + 40 + 60 &
73.5mm ofset bore giving you 1380 ccs
i would buy the DAVID VIZARD book tuning the A series engine its the yellow book you want the revised & updated version
this will give you an excellent grounding.
Edited by BENROSS on 22nd Sep, 2005.
