Home > General Chat > Specialist components
1380turbo
Member #: 1211
Working up the BHP ladder.
Hi Guys, haven't posted for a while but need some help. Spent the last few months rebuilding the 1380 and adding a specialist components injection system and full engine management. Doesn't seem a bad kit with most bits fairly straight forward fit etc.
Have been trying to start the fit this weekend and can't get any sort of spark. Initially set the crank pick up at 0.7mm and have progressively moved all the way to 1.2mm in 0.1 increments. No sparky spark. Fuel pump primes etc and runs, injectors seem to be doing something so assume the ECU is up and running. Using a KAD front damper with built in trigger wheel.
Any ideas?
sim_ou_nao
Member #: 114
Porto/Portugal
Have you cut the extra tooth in the trigger wheel?
Edited by sim_ou_nao on 14th May, 2017.
Pedro Silva
1380turbo
Member #: 1211
It's already there. It's a std 36-1 pattern
Is the sensor in the correct position for the cut out? And is the sensor the correct polarity? For the breif time I ran the kit, I used the sensor that came with the kit and the med trigger wheel and dns sensor bracket.
Also check you have 12v to the fuses
If the injectors are injecting, it's unlikely to be the trigger wheel and sensor. The injectors and sprk are all being initiated from the crank speed.
Check the wiring to the coil(s).
1380turbo
Member #: 1211
Ok so a few bits to check. Thankyou guys as always.
Gr4h4m what did you find wrong with the system? Or shouldn't I ask. Lol.
D4VE
Member #: 10749
lowestoft suffolk
Give john at sc a call
Nothing gets past Dave lol
So connect to the ecu and see if you're getting any signal from the crank ?
RPM reading ? anything ?
The ECU may be live, your fuel pump priming seems to indicate that but unless it sees a suitable crank trigger it isnt going to do much else.
I'm not that familiar with the SC ECU (Typhoon ???) but surely the tuning software has an RPM display ?
That way, as Stevie says, you will see if the crank signal is actually being read.
If the software is any good at all, it will show the cranking RPM. It might not be a large number, probably about 150-200 RPM depending one engine CR, battery condition etc., but it will show if the crank trigger is working.
Then, if the injectors are actually firing (are you absolutely sure ?) it has to be ignition wiring or something set wrongly in the software.
If the wheel position was wrong you should still get a spark, just at the wrong time. I presume when you say no spark, that is with the plug actually removed, rather than no spark at the right time ?
Are you using SC's "base" settings for an A series ?
