| Home > Help Needed / General Tech Chat > Losing power.... continuously.... back in the game!! | |||||||
1142 Posts Member #: 10165 Post Whore Stansted, Essex |
19th May, 2017 at 02:59:02pm
Hello again..
Edited by evad1980 on 24th Nov, 2017. |
167 Posts Member #: 11091 Advanced Member |
19th May, 2017 at 03:31:01pm
That sucks - what car is it and specs? |
19th May, 2017 at 03:52:35pm
Pull the leads off one by one and see if it makes any difference. I used to always have issues with plugs fouling up. In the 13's at last!.. Just |
19th May, 2017 at 04:13:46pm
All sorted lads.. no oil in dashpot!! doh!!
19th May, 2017 at 06:56:26pm
Ok... not so sorted!.. Took the missus out for a spin.. all going well and same thing after about 6 or 7 miles.
19th May, 2017 at 07:06:19pm
its been an age since ive worked on an SU but had an e-type with strombergs recently that was doing the same on 2 of the carburettors. long story is on the strombergs the needle is adjustable thro the dashpot and there is a seal at the bottom of the dashpot, an it was knackered. I dont recall SU's especially the later ones, having adjustable needles but if I were you I'd be dismantling the dashpot and having a noesy, you shouldnt be loosing oil. I'd also suggest a thicker oil like ATF. turbo 16v k-series 11.9@118.9 :)
19th May, 2017 at 07:31:32pm
Ok thanks.. for sure I'll be dismantilling it tomo for a nosey. What about 3 in 1 oil, that stuff any good cos it drove great after I put that in... must be losing the oil somehow, I'll check all seals.. cheers.. |
19th May, 2017 at 08:25:14pm
You want something thick in with a turbo.
![]() 2975 Posts Member #: 10749 Post Whore lowestoft suffolk |
19th May, 2017 at 08:25:46pm
Was going to say dashpot oil before i ready any comments..
Nothing gets past Dave lol NOTHING GETS PAST ME!!
1/4 mile 14.7 @ 96mph 12psi boost Showdown class A 2nd place 18.6 @ 69mph |
19th May, 2017 at 08:33:35pm
3in1 is to thin, and the standard SU oil has never worked for me either. 20/50 almost always seems to work better.
21st May, 2017 at 05:18:37pm
So thought I had the problem solved.. obviously not.
21st May, 2017 at 06:14:48pm
Annoying but you need to fault find in a methodical way.
21st May, 2017 at 06:46:22pm
It won't be the FPR, the symptoms you have can't be caused by an FPR fault. I'd adjust the pressure back to 4ish psi.
21st May, 2017 at 07:02:20pm
Is it time for the T piece trick? |
976 Posts Member #: 3228 Post Whore North of the Netherlands |
21st May, 2017 at 09:02:41pm
Tom's suggestion triggered me; are you running an inline fuel filter?
Dazed and Confused.... |
21st May, 2017 at 09:06:44pm
Yeah annoying as hell. Yes it is/was an estate. How did you sort that Tom?
21st May, 2017 at 09:11:23pm
Ah ha.... yes I am... I'm using the one from minispares. The one with the 8mm inlet and outlet. Designed for use with a turbo.. |
22nd May, 2017 at 09:04:05am
Not sure if that has a dedicated in and out but did you put it in right way round?
On 21st May, 2017 evad1980 said:
Ah ha.... yes I am... I'm using the one from minispares. The one with the 8mm inlet and outlet. Designed for use with a turbo.. Dazed and Confused.... |
22nd May, 2017 at 12:15:25pm
With mine it was a short bit of tube with the union into the tank, it had a kink in, I replaced it with another one without the kink which sorted it.
22nd May, 2017 at 04:55:25pm
Yeah I'll inspect all of those possible causes..
![]() 517 Posts Member #: 9931 Post Whore brighton |
22nd May, 2017 at 06:03:45pm
My estate was sucking up the crap in the tank and blocking the pickup so I removed gauze and put a inline filter |
22nd May, 2017 at 06:04:24pm
do the van/ estate tanks have the filter on the pickup pipe in the tank like the saloon tanks? just wonder if that could be clogged if its an old tank.
22nd May, 2017 at 06:22:52pm
I can't remember what's the setup in the tank, was ages ago I had it off. I may have to start there by pulling it off again and doing an inspection. I may need to replace the float anyway...
22nd May, 2017 at 06:38:32pm
How have you plumbed in the tank? Have you got a lifter pump? or a swirl pot? or anything spangly like that?
22nd May, 2017 at 07:08:23pm
So from tank to inline fuel pump, one of these...
and the what-ja-ma-call-it fell down wayyyy too quickly! Tipped it out Put some engine oil in it cured it!
