| Home > Help Needed / General Tech Chat > Rusted boot floor section | |||||||
81 Posts Member #: 11403 Advanced Member |
22nd May, 2017 at 03:44:46pm
My boot floor has rusted through where it meets the back end of the car. Is it right that I'm going to have to remove the rear valance and if so can it be removed in a way that I can reuse it? I saw a repair section on minispares but didn't realise it sandwiches between the valance and body section
22nd May, 2017 at 03:53:53pm
To do it right the rear valance needs to come off. They aren't a lot of money to replace, or at least they didn't use to be.
22nd May, 2017 at 06:06:04pm
if the bood floor needs replaced, the likelihood is the valance will need doing to anyway.
22nd May, 2017 at 06:54:25pm
The valance is solid that's the annoying thing.. I think the previous owner just bodged it up. There was a metal plate glued over a rust hole in the boot with seam sealer around it to make it look like it was done right...
22nd May, 2017 at 06:54:28pm
22nd May, 2017 at 07:12:46pm
Then you'll need to drill all the spot welds out if you want to save it. On 11th Feb, 2015 robert said:
23rd May, 2017 at 06:31:30am
Where about are all the spot weld s for it?
23rd May, 2017 at 06:54:54am
Sorry but if your asking the question of where are the spot welds then your far from capable of doing the job in an acceptable manner. |
23rd May, 2017 at 01:08:57pm
I work at a Bodyshop I just wanted to simply know where they were as I don't have the car with me to look at and so I have an idea when I come to attack it. At work full repair guides are available but I don't think classic minis will be on the database.. |
29th May, 2017 at 01:04:45pm
I managed to get a look today... The previous owner has just put 6 tack looking welds across the back panel, boot floor and valance... Looks like it will come off quite easy Edited by steve2016 on 29th May, 2017. |
29th May, 2017 at 05:23:11pm
just as well your taking it off if that is how it was repaired previously |
30th May, 2017 at 03:16:59pm
Was thinking of bonding the panel on. At work when a new 1/4 is fitted they are mainly bonded on now instead of welded, a few welds go on but mainly its a high strength bond used now.
![]() 1733 Posts Member #: 1910 Post Whore Wilts |
30th May, 2017 at 04:29:28pm
Why not weld it like should be........
the pissed up clown stood back up, did a twirl and left bollock naked, |
30th May, 2017 at 04:32:58pm
I've known people do it both ways. The only downside with bonding is that you have to rely on the panel being the right shape to start with whereas welding allows it to be pushed and pulled into place. The closers would still need to be welded on to the boot floor i'd suspect |
![]() 2975 Posts Member #: 10749 Post Whore lowestoft suffolk |
30th May, 2017 at 10:39:23pm
Seen a few people use riv-nuts n bolts to make it removeable On 24th Oct, 2015 jonny f said:
Nothing gets past Dave lol NOTHING GETS PAST ME!!
1/4 mile 14.7 @ 96mph 12psi boost Showdown class A 2nd place 18.6 @ 69mph |
![]() 1043 Posts Member #: 10424 Post Whore Swansea boyo! |
2nd Jun, 2017 at 07:01:13pm
Mine just bolts on and off :)
On 30th May, 2017 D4VE said:
Seen a few people use riv-nuts n bolts to make it removeable They don't die, they just get faster! |
no spot welds to drill.
