Home > Introduce Yourself > SU limitation
Gpametroturbo
Member #: 11572
By intro I race a GPA metro Turbo (computervision) and have problems with power delivery on anything that is not full throttle or on boost above 5000 rpm. I am thinking that the dash pot that lifts as a vacuum is created by Venturi effect is reacting unpredictably as the airspeed goes up to way beyond that designed. At 250+ Bhp (1.5bar) the airspeed through the carb could require a rethink of the jet bridge and Venturi holes under the dash pot piston. Is the airspeed under the piston drawing it and the needle down more than the vacuum is pulling the piston up? I will try to rig a simulator so we can phisicaly see what's happening but have any members come up with a solution already?
well, i'd start here...
http://www.ebay.co.uk/itm/SU-HIF7-Pair-Of-...pIAAOSwq1JZLa~f
The air speed is no higher than N/A with blow through, just the air density is higher.
metroturbo
Member #: 989
North Yorkshire
Have you tried a stronger spring in the dashpot, as used on the Maestro and Montego turbo? People have had them running over a bar boost still using the single SU on a 2 litre engine.
you need a stronger spring or springs, to make sure the needle doesnt rise to its maximum station before maximum air flow (not boost) is reached
data log the needles position and alot of things will become clear
I doubt you're reaching the limit of the carb. More likely, you have a setup issue.
One of the USA based members spent a long time looking at needle profiles and the position of the dashpot piston for different load sites. Made for very interesting reading, but I can't recall the topic title or the guys username...
Have you got a wideband to determine your fueling or are you guessing that you need to modify the carb? My experience is that the stock carb and plenum restrictor is basically as perfect as you'll get ( except for the poppet butterfly valve). The engineers didn't arrive at that by pure luck.
Edited by turbodave16v on 31st May, 2017.
hazpalmer
Member #: 9038
Carlisle, Cumbria
http://www.turbominis.co.uk/forums/index.php?p=vt&tid=159683
Evoderby
Member #: 9987
Amsterdam
I doubt you're reaching the limit of the carb. More likely, you have a setup issue. My experience is that the stock carb and plenum restrictor is basically as perfect as you'll get ( except for the poppet butterfly valve). The engineers didn't arrive at that by pure luck.
Interestingly enough I noticed that the Grp A turbo running on swiftune's dyno recently doesn't use a plenum but had a boost pipe running straight into the carb's mouth.
So why not explain your problem ? Your setup ?
And what power do you believe you have, or want to have ?
Running without the OEM plenum is with hindsight what caused me most of my problems some 20+ years ago when I ran mine.
Back then I never fully appreciated what the restrictor/straight inlet section was for.
I ran open plenum to enable IC fitment etc and it did take ages working with the carb to get it all to work well. It was never perfect, but it was pretty good. Havent a clue what AFR's etc were, as no such thing as widebands etc back then, but I drove it daily for a few years and could run 25psi without issue ( well other than expected clutch/gearbox/HG related problems )
So as others say, the chances of being at the limits of the carb here, are very unlikely. And I'm near sure some guys with the Maestro's or Montego's still ran a single carb near 300hp too ?
fab
Member #: 100
Parisien Turbo Expert
Paris' suburb
Hello, to start 250 bhp+.. mega lol , bref.
your trouble seem to be associated by a bad carb set up as stated by members.
Start from a stronger spring ( you should have a green one to began) and needle then the advance curve can play a bit when this is right you can look at pitot tube to get rid of plenum restrictor but leave alone carb bridge and venturi hole.
SU can look like a bike carb but it's not teh effect on venturi holeis here compensated by dashpot spring so u fine tune the level of travel/by de-pressure with this
