| Home > General Chat > Nitrous oxide | |||||||
32 Posts Member #: 10074 Member new Zealand |
24th Jul, 2017 at 09:39:23am
I'm assuming I will get very mixed opinions on this one 😁..
24th Jul, 2017 at 12:22:16pm
well, theres been a few people on here using it to good effect, most notably, Carl Austin on the Don, Steve1275 on his midget, and Miniwilliams,
24th Jul, 2017 at 06:34:06pm
The results can be very impressive.
24th Jul, 2017 at 07:33:58pm
every car i have fitted nitrous too has either had its floor pan bolts come out or blew the welds on the intake manifold
Yes i moved to the darkside |
24th Jul, 2017 at 07:36:17pm
actually fitted a couple systems, never had an issue, wizards of nos would be my first choice ( as there about 6 miles from me lol )
![]() 2975 Posts Member #: 10749 Post Whore lowestoft suffolk |
24th Jul, 2017 at 09:11:45pm
On 24th Jul, 2017 Brett said:
every car i have fitted nitrous too has either had its floor pan bolts come out or blew the welds on the intake manifold either way i had to rip apart the blocks and replace the piston rings i fryed But brett i bet 'you had enough nos in there to blow yourself up! PERIOD!' On 24th Oct, 2015 jonny f said:
Nothing gets past Dave lol NOTHING GETS PAST ME!!
1/4 mile 14.7 @ 96mph 12psi boost Showdown class A 2nd place 18.6 @ 69mph |
25th Jul, 2017 at 12:23:57am
Ok sweet does anyone have any photos of the setup in the mini? |
![]() 865 Posts Member #: 951 Post Whore Bromsgrove |
25th Jul, 2017 at 08:23:39am
Agree with the above. Use WON, keep it simple, NOS is now £8 per lb I use about half lb every run at the strip with 50 bhp nozzles. 'Where does the engine go?' |
27th Jul, 2017 at 09:02:09am
Steve1275 do you have photos etc of your setup.? |
28th Jul, 2017 at 05:55:27pm
every car i have fitted nitrous too has either had its floor pan bolts come out or blew the welds on the intake manifold either way i had to rip apart the blocks and replace the piston rings i fryed But brett i bet 'you had enough nos in there to blow yourself up! PERIOD!' ![]() ![]() ![]()
i did but johnny tran's cousin lance shot it the shit up
30th Jul, 2017 at 04:33:30pm
The nozzle for fuel and NOS goes into the inlet about a foot before the plenum, on a section that runs uphill to the engine so that any liquid NOS drains away from the engine. The solenoids are on the inner wing, operated by a WOT microswitch on the carb. I took the fuel feed out from the line before the fuel regulator, this may give too much fuel pressure as it runs very rich on NOS, but safer that way. NOS bottle is in the boot. Nominal 50 bhp jets give about 60 on the RR. Hope this helps. 'Where does the engine go?' |
30th Jul, 2017 at 05:01:36pm
Spotted the TTP sticker. Malc is a good guy.
30th Jul, 2017 at 08:27:47pm
Sure is Tom, and the author of the 'nuttier than squirrel shit' quote on the back of the car 'Where does the engine go?' |
![]() 730 Posts Member #: 1791 Post Whore Cranleigh, surrey |
1st Aug, 2017 at 01:52:26pm
I used it on my Turbo mainly to get the T3 to spool quicker, and then on the top end, used a NOS system from the usa, had a nice simple programable controller that was very adjustable, was it worth it, yes for the straight lines, no on the road. "Cars are a lifetime of pain" |
