Home > Help Needed / General Tech Chat > What Needle???
Soton1310Turbo
Member #: 265
Southampton
Anyone got an idea what needle should be in my Jreg MiniCooper?
It has got a K&N, LCB and RC40 nowt else done yet
what are the needles supplied with Stg 1 Kits?
Need to order one as my car wont idle due to scores all over the needle,
It's not vertical scores from ware, but big gouges out at the base of the needle, No idea how they got there only just bought the car.
How long is a piece of string.......
More seriously, get it on the rollers.
I'd say a decent starting point would be an MG Metro needle, BDL (?) from memory, but that could be wrong.
Soton1310Turbo
Member #: 265
Southampton
I'm only after one of the standard profiles, it's only a standard 1275 after all
just not sure what the codes are
and the only ones i've got are Turbo ones or ones which have been fiddled with on a RR.
I'm not after 100s of bananas just something that'll idle and drive nicley
currently cos of the scores sometimes it idles fine other times it stalls and other times it idles @1500rpm
done a head gasket and engine seems in good nic, all the ignition stuff is tip top, I stripped and cleaned the carb the other day and found all else was fine bar the needle.
The car only gets me to and from work, when I can't be bothered to run or cycle about 3.5 miles thats all
cheers all
Keith
Edited by Soton1310Turbo on 23rd Sep, 2005.
As I said, try a BDL.
turbo hogster
Member #: 178
stowmaket suffolk
still need to put it on the rollers as it will be way buy just altering the exhaust and inlet side of things.
as tom says fit a bdl and then get the operatrer to tweek it.
giallofly
Member #: 164
The Stig..
Newport Pagnell
If your engine is a genuine 1275 Cooper it has the same engine as an MG mutro, the profile is different to a standard 1275. try taking a good look at the plugs after run, they tell a tale.
Soton1310Turbo
Member #: 265
Southampton
propbaly go with the std BDL
cheers all
Do a search for AC Dodd on whichever froum he's on nowadays... He's usually the best at suggesting needles.
turbo hogster
Member #: 178
stowmaket suffolk
http://p211.ezboard.com/bminiclassic
find him on here yes ac will give you a needle you need but will also say take it to a rolling road.
as thats the only way to get here running spot on all the way through the rev range.
Nick
Member #: 154
Midlands
http://www.winsu.co.uk/
try that for a rough idea of for a needle, just bang in your engine spec and see what it says :) Pretty sure BDL will be fine though as thats what was in my carbed cooper before.
Soton1310Turbo
Member #: 265
Southampton
cheers all
got a BDK on the way from mini spares at the mo
Bud winsu looks pretty handy though as a guide obviously
