Home > Help Needed / General Tech Chat > Which clutch
JamesV8
Member #: 11697
The clutch on my mini is starting to slip. Which one would you guys recommend please?
Metro turbo engine, standard apart from different pistons but not sure which.
Road use and track days.
I will be doing some mods in the future so it would be nice if it were able to cope with that too if possible.
If poss i didnt want a paddle clutch plate.
The mini spares website lists an uprated pressure plate. Would this be the one to go for? http://minispares.com/product/Classic/Clut...ack%20to%20shop
With
I will probably get a lighter flywheel and new push rod, arm, oil seal etc. Anything else worth changing while i am getting oily?
Thanks
With a standard engine, I see no reason to go mad with the clutch.
The parts you have linked should be up for the job.
Edited as it was fooking nonsense!
Edited by wil_h on 24th Mar, 2018.
jonny f
Member #: 9894
Dorking
MED do some reasonably priced kits for a Verto clutch ready to fit with flywheel. They’re also balanced which you would have to do if you just bought the bits from minispares.
If your thinking of going for more than around 120bhp I would consider making up an RTS (twin spring verto).
JamesV8
Member #: 11697
Thanks guys.
Just spent ages looking at all the shiny bits on the med website!
JT
Member #: 637
Hertfordshire
I use a med lightened verto flywheel and two 1275 springs as that's what I had on the spares shelf. (RTS) I havent manged to get it to slip yet at 20psi.
Although the head gasket did let go 😂
My build thread..
