Home > Help Needed / General Tech Chat > Brake line flare type
longy
Member #: 2727
Bicester
I need to make some new brake lines to accommodate a proportioning valve, but i cant seem to get a clear answer on the type of flare to use. am i correct in saying a male fitting requires an SAE single flare and a female fitting requires a double flare.
I'm looking at getting this tool and want to make sure its the right one.
https://www.ebay.co.uk/itm/Classic-Mini-Han...t-/282619607826
1972 998 TURBO SLEEPER
Yep and that tool will do exactly what you want.
Make sure you use Kunifer pipe rather than copper or steel
longy
Member #: 2727
Bicester
brilliant thanks Will,
t3gav
Member #: 229
Gavin@minispares.com
kent
Double flare on all kunifer/copper lines, single flares are only used on steel lines.
