| Home > Help Needed / General Tech Chat > TM approved pistons?? | |||||||
![]() 384 Posts Member #: 4215 Senior Member |
24th Sep, 2018 at 12:01:22am
hi folks
24th Sep, 2018 at 06:47:50am
Sounds more like valve guides/stem seals to me from your description of the symptoms. Coasting equals high vacuum so it pulls oil down past the valve stem. When you open throttle that oil then exits stage rear as a cloud of blue smoke.
24th Sep, 2018 at 09:06:17am
Most likely stem seals as suggested above. With the poor quality of rubber these days the ordinary stem seals don't seem to last and soon harden. Though they're a little more expensive I only use the MPI spec (brown) viton type now as they're much better.
24th Sep, 2018 at 11:27:01pm
hmmm, these where changed about 4/5 years ago but the car has bent siting for at least 3-4 years.(needed a break from it, before i set it on fire) i used Dupont ones. do these get brittle when not used?
Edited by c2_mad on 24th Sep, 2018. |
6th Oct, 2018 at 01:08:34am
anyone got any input on a good alternative to the omega pistons? |
6th Oct, 2018 at 01:28:05pm
21253 from minispares are ok. |
8th Oct, 2018 at 11:25:51pm
On 6th Oct, 2018 jonny f said:
21253 from minispares are ok. are you runing them? how many psi have you put them under? |
9th Oct, 2018 at 07:18:05am
Shouldn’t have a problem at 15psi if everything is correctly set up. Others have pushed more through them if I recall correctly. On 7th Oct, 2010 5haneJ said:
9th Oct, 2018 at 08:11:10am
Mine took 10 psi for many track days. They were taken out to 14cc.
9th Oct, 2018 at 11:42:42am
thanks for the feedback guys |
