| Home > Help Needed / General Tech Chat > Oil Drain Problems | |||||||
![]() 143 Posts Member #: 2764 Advanced Member Halesowen |
26th Mar, 2019 at 01:38:36pm
Need a bit of advice with oil drains. GT1752, home made manifold.
1994 Mini Mayfair, 1330, Mspd Ph2 cam, Benross turbo head, 9:1, GT1752, TT Intercooler, MegaJolt, BMW M3 leather seats. |
26th Mar, 2019 at 01:41:31pm
Speedo drive? Think some people have returned it there before. |
26th Mar, 2019 at 01:49:51pm
Possible - but, then I would have to swap to an electronic Speedo and drive I assume? 1994 Mini Mayfair, 1330, Mspd Ph2 cam, Benross turbo head, 9:1, GT1752, TT Intercooler, MegaJolt, BMW M3 leather seats. |
26th Mar, 2019 at 02:04:18pm
I think he means drill and tap a fitting into the side of the speedo housing. It unbolts from the gearbox so you can do the mod without stripping the gearbox. You could keep the speedo workings as they are.
26th Mar, 2019 at 02:23:37pm
On 26th Mar, 2019 Tom Fenton said:
I think he means drill and tap a fitting into the side of the speedo housing. It unbolts from the gearbox so you can do the mod without stripping the gearbox. You could keep the speedo workings as they are. Right, I get you. Number 25 on here? https://www.moss-europe.co.uk/shop-by-model...rnals-mini.html That would be a possibility. I think I'll get the spare block and head on the engine stand later so I can see how much slope I can get to the fuel pump drain. It's impossible working down the back of the engine in the car! My spare engine is an "A+" though - are the fuel pump locations the same as an "A" block? 1994 Mini Mayfair, 1330, Mspd Ph2 cam, Benross turbo head, 9:1, GT1752, TT Intercooler, MegaJolt, BMW M3 leather seats. |
28th Mar, 2019 at 01:45:34pm
So, I've got it on the bench, and there is a drop to the fuel pump hole, just not a huge one.
Edited by ian2000t on 28th Mar, 2019. 1994 Mini Mayfair, 1330, Mspd Ph2 cam, Benross turbo head, 9:1, GT1752, TT Intercooler, MegaJolt, BMW M3 leather seats. |
28th Mar, 2019 at 02:34:24pm
Just to pinch back a bit of space, can you make that flange onto the turbo core thinner? Looks very thick.
28th Mar, 2019 at 11:42:37pm
Why not go from that alloy base, to say 19mm directly into the block ? Looks like you could get an almost straight shot at it and maybe even with a little downhill slope.
28th Mar, 2019 at 11:44:06pm
Huronspeed in the US do these nice compact drains for a T3.
Edited by stevieturbo on 28th Mar, 2019. 9.85 @ 145mph
