Home > General Chat > sodding experience
1976_mini
Member #: 259
grays, essex
The next stage of the budget engine build for me was to start stripping it down. Well as you all know, the clutch and flywheel need to be removed. Anyways, i undid the bolt on the end of the crank, attatch th flywheel puller and off i go! An hour i later i give up and spray it with the good ol wd40 to try and remove the rust.
I come back a few days later hook up the flywhel puller and go agen. 45minutes later and it still hasnt budged, so out comes the grinder and i start yomping of lumps of old pressure plate. still nothing! next i try the blow torch and i heat it up till its glowing, nuffing! about to give up n pay someone to do it when i relise i hadnt taken the washer out from under the bolt! 15min later n its off!
I hate learning from experience. at least ill neva do that agen!
it may b small but it purfectly formed
http://photobucket.com/albums/v340/1976_mi...roject%20turbo/
Ha ha, unlucky mate, atleast there was no harm done *smiley*
If you dont make mistakes you never learn, no1 does everything right first time thats for sure.
my first attempt-
whats a flywheel puller?
i cant afford one of those, wheres the crowbar?
2 days later i went off and bought one!
i have been in engineering over 30 years and i still make mistakes!
like the cam timing i got wrong on my mini*blush**blush*
it does happen but you learn the hard way
still, admitting it to others is even harder as it dents you eago a touch!
most peeps like to keep thing to themselves & admit nowt!*wink**wink**laughing*
There are some things you admit, but some are better kept to yourself!!!!!!!!!!!!!!!!
like me snogging one of my mate mums?
T3Tone
Member #: 252
Sunny suffolk
LOL@wolfie, nowt wrong with that*wink*
-MINI CLUBMAN 1380 TURBO-
Remember to remove the little plate behind the bolt *wink*
I've heard worse confessions wolfie, my mate went further than that with his gf's mum...... *happy*
all depends how many mums he has!
she *happy*
antman
Member #: 358
Snetterton, Norfolk
Always good fun taking a flywheel off!!!
I did the one on my new engine today and used an impact gun on the highest torque to take it off!! Still wasn't liking it though, took about a minute on huge torque. Its a good job its the college tools and they have a huge compressor for the whole of the motorsport workshops.
turbo hogster
Member #: 178
stowmaket suffolk
dont worry mate you aint the first and you wont be the last.
we have all done somthing stupid
i once wondered why when i changed from a 286 cam to a 276 cam i lost 14 hp and found out my timing was out buy 13 deg oooppppsss.
