Home > Help Needed / General Tech Chat > Still smoking
flyingturd
Member #: 4008
near cardiff np12
After loads of issues with my engine I’ve now rebuilt it, rings, hone, cam bearing, mains etc and .......... it’s still smoking 🤬
Previous to this I rebuilt the turbo, valve guides good with new seals
Any possible answers? Maybe head cracked???
It’s quite a white smoke.
AFR gauge is running 13.
Starts perfect and revs fine
Plug colours?
What’s the oil return like ? Free flowing and of a decent size ?
Phil.
good thought from Phil,
now i'm at a PC,
any signs of oil burning anywhere? on the plugs, in any of the exhaust ports inlet ports etc...
I remember Any had an issue with oil getting down the side of one of the guides, ( between the guide and head)
White smoke sounds like it's from the turbo. Oil return is worth a check.
shane
Member #: 1246
Lowestoft, Suffolk.
High oil pressure causing passing of the turbo oil seals?
Shane
flyingturd
Member #: 4008
near cardiff np12
Thanks for the replies.
oil return is going into the old fuel pump with a new pipe and its new.
turbo has been rebuilt
plugs are a little black but havent properly run it
shane
Member #: 1246
Lowestoft, Suffolk.
Section about oil feeds may be noteworthy.
https://www.precisionturbo.net/tech/PDFs/PT...mmendations.pdf
Shane
Edited by shane on 11th Apr, 2019.
Just because the turbo has been rebuild doesn't mean that it's right. It might be worth taking it off and seeing if it still smokes. If so you have your answer.
shane
Member #: 1246
Lowestoft, Suffolk.
Same goes for the engine, only takes a small oversight.
Shane
If its brand new rings, hone etc, do you just need to drive it under load to make the rings bed in?
As Tom said, if it’s a new build you’ll need to bed the rings in. Pull the boost hose off the compressor housing and see if there’s any oil in there to.
Phil.
evolotion
Member #: 83
Glasgow, Scotland
gotta disagree (respectfully) with new rings and a hone, if its ok it will be smoke free from the get go.
I would definately try it without a turbo, and then with a spare head, even a crappy old 998 head should do for testing purpouses? then your back to rings / bore.
Denis O'Brien.
lots of breathers ?
