Home > Help Needed / General Tech Chat > Regulator to carb pipe sizes
Will
Member #: 11091
6mm carb connections
Just measured the regulator and it’s circa 8.7mm
Is everyone running reducers or how does this work haha
Yup. Just a reducer between the two.
In the past I’ve got the 6mm hose, put one end in boiling water for a while to soften it up, and managed to stretch it onto the regulator tails. Bit rough but nearer than reducers. Once it’s on it’s not coming off without a knife!
metroturbo
Member #: 989
North Yorkshire
From the factory it was a 6mm hose stretched over the regulator connector.
As above. I just stretched the hose to fit the reg. 20+ years later it’s fine.
Phil.
Easiest way to stretch it is with a tapered end of a heel bar. Boil the hose, warm the bar with a blow lamp, a very thin smear of grease, and get to pushing and twisting. It seems to help leaving it on the bar to cool, then repeating (dip in boiling water and re-warm the bar). Slides on like a glove; no effort!
t3gav
Member #: 229
Gavin@minispares.com
kent
I use this http://minispares.com/product/Classic/hm-4-5.aspx but have stretched the hose in the past too.
Will
Member #: 11091
Thanks gav, yes ive got these but cant decide whether i like all the connections or want to risk the stretched pipe! *tongue*
BronkoMini
Member #: 10610
I used a purl pressure gauge with one end 6mm and the other 8mm
https://flic.kr/p/2fyipTF
