| Home > Help Needed / General Tech Chat > Carb problem supercharged blow through Hiff44 | |||||||
75 Posts Member #: 1956 Advanced Member |
30th Jun, 2019 at 10:18:50pm
Hi All,
Edited by remko on 30th Jun, 2019. |
30th Jun, 2019 at 11:56:56pm
How are you pressurising the float chamber ?
113 Posts Member #: 11786 Advanced Member |
1st Jul, 2019 at 05:20:36am
I did have the same problem and it was a broken needle. Since you tried different needles it shouldnt be your problem.
1st Jul, 2019 at 06:06:31am
@Phil:
1st Jul, 2019 at 06:06:35am
@Phil:
1st Jul, 2019 at 08:17:34am
The turbo carb setup relies on the restrictor ring inside the standard plenum chamber to provide a pressure differential for the fuel chamber to pressurise. If you are running without that, then I think that is your issue.
2nd Jul, 2019 at 06:34:40am
Tonight I'll perform some tests. I'm going to Vintage Mini's, he has currently a running turbo engine mounted on a testbench. This makes it very easy to do testing with my carb:
2nd Jul, 2019 at 07:50:17am
do you hve a fuel pressure regulator connected to the boost source so it raises fuel pressure as the boost rises ? Medusa + injection = too much torque for the dyno ..https://youtu.be/qg5o0_tJxYM |
5th Jul, 2019 at 12:19:23pm
Tested @ Vintage mini’s on a turbo engine that was on a dyno.
23rd Jun, 2020 at 08:54:19pm
Long time ago, short update...
Edited by remko on 23rd Jun, 2020. |
24th Jun, 2020 at 02:16:50pm
I'd be interested in seeing more about this has been done. Sounds like a nice little project.
On 23rd Jun, 2020 remko said:
- Height of carb piston visible (12 LED’s) on dash next to wideband lambda! Now I know what part of needle needs grinding. |
51 Posts Member #: 10080 Advanced Member Holland, Eindhoven |
24th Jun, 2020 at 06:43:17pm
Hi Remko can we get in contact in Dutch. Im trying the same and got it only idling. But till last time it worked out. I made a mistake by the flowchamber. Small piston upside down. |
24th Jun, 2020 at 07:40:49pm
No rocketscience:
On 24th Jun, 2020 metroturbo said:
I'd be interested in seeing more about this has been done. Sounds like a nice little project. On 23rd Jun, 2020 remko said: - Height of carb piston visible (12 LED’s) on dash next to wideband lambda! Now I know what part of needle needs grinding. |
24th Jun, 2020 at 07:41:57pm
On 24th Jun, 2020 Bill said:
Hi Remko can we get in contact in Dutch. Im trying the same and got it only idling. But till last time it worked out. I made a mistake by the flowchamber. Small piston upside down. PM sent! |
28th Jun, 2020 at 05:40:14pm
Finally it runs without any issues!
30th Jun, 2020 at 12:25:50pm
Love it. On 24th Jun, 2020 remko said:
No rocketscience: 12 leds connected to 12 reed-contacts (or switch). Reed contacts in polyester block to fit to dashpot. Piston machined to hold a half 5mm whiteboard magnet. Simple, but very usefull while tuning the AFR! |
