Home > Help Needed / General Tech Chat > hellp
tabac11
Member #: 11929
I have a problem with my mini, fill the pistons with gasoline and crash what will be the problem
tabac11
Member #: 11929
I think it is due to the injection system..someone has the scheme of that thanks
We need a bit more info, what injection system, is this a new fault, and some pics of the instal would help greatly.
tabac11
Member #: 11929
Its not injection system. Im using a traditional carb. But sometimes it fills up / drench de pistons . Any help sugestions please?
too much fuel pressure .
tabac11
Member #: 11929
Anyone have the mounting scheme or someting?
Steve220
Member #: 11017
Shropshire
I take it English isn't your first language. I'm still trying to work out what is wrong with the car in the first place.
if its only an issue some of the time then check the fuel pressure is not too high, it should be 2-4 psi maximum.
Also, replace the float valve in the bottom of the carb as these can wear and leak, or have debris hold them open. also fit an inline filter going to the carb.
