| Home > Help Needed / General Tech Chat > Non selection of first gear (or jumping out) after gearbox rebuild | |||||||
45 Posts Member #: 9406 Member Tadley, Hampshire. |
28th Oct, 2019 at 11:37:10am
I am hoping someone can point me in the right direction with this very disappointing problem. The gearbox in question is in an ERA Turbo Mini. I like to do things myself but I am very slow, methodical and exact - my aim is to preserve the ERA as it left the factory - she is more for show than go these days!
28th Oct, 2019 at 12:43:20pm
Has he put the 1/2 (and also reverse) synchro boss the wrong way around on the synchro hub? It will fit either way round but sits biased over to one side. Ask me how I know!! Have you a photo of the box internals before you installed it?
28th Oct, 2019 at 01:25:50pm
Hi Tom, thank you for your reply - I have a picture of the box before being professionally rebuilt - but unfortunately not after. I do have another here to compare it with when I take it out again. Some one else agrees with you that the gear has been put in the wrong way - would also explain the position of first being slightly diagonal now!
28th Oct, 2019 at 10:52:53pm
Would reverse still be ok with the 1-2 selector the wrong way around?
On 28th Oct, 2019 Tom Fenton said:
Has he put the 1/2 (and also reverse) synchro boss the wrong way around on the synchro hub? It will fit either way round but sits biased over to one side. Ask me how I know!! Have you a photo of the box internals before you installed it? In the 13's at last!.. Just |
29th Oct, 2019 at 11:19:30am
I have discussed this problem with the "gearbox specialist" alarmingly he did not seem to understand - "The centre of the synchro hub is the wrong way round" He was focused on the whole synchro hub saying that it could not be the wrong way around.
29th Oct, 2019 at 01:20:01pm
http://www.minispares.com/product/Classic/...spx%7CBack%20to
29th Oct, 2019 at 02:33:37pm
Hi Tom, thank you for your very clear explanation - I guessed that you had learnt this from bitter experience - I doubt that you are the only one! I will eventually finish this thread with the "autopsy"
Edited by ricsdad on 29th Oct, 2019. |
29th Oct, 2019 at 06:15:54pm
Here is a slightly more obvious photo of the offset Tom mentions.
Edited by Rod S on 29th Oct, 2019. Schrödinger's cat - so which one am I ??? |
29th Oct, 2019 at 09:10:47pm
I think ricsdad is nearer the mark in that the centre of the synchro hub is potentially the wrong way round, not the outer. |
29th Oct, 2019 at 11:47:50pm
I had a load of problems with gear selection once. Turned out to be a problem with the shifter, a cheap quickshift rip-off.
976 Posts Member #: 3228 Post Whore North of the Netherlands |
1st Nov, 2019 at 10:42:18am
Do you have an endoscope?
Dazed and Confused.... |
![]() 928 Posts Member #: 326 Post Whore bradford, west yorks |
13th Jan, 2020 at 10:24:13pm
I had a problem with mine popping out of reverse and first and had the gearbox rebuilt to find it was a problem with the selector mounting, the one attatched to the gearbox above the rod.
Edited by pot_dan on 13th Jan, 2020. |
