| Home > Help Needed / General Tech Chat > Bogging Down | |||||||
16 Posts Member #: 11921 Member |
29th Mar, 2020 at 06:31:08pm
Hi Everyone,
Edited by Glun34 on 29th Mar, 2020. |
29th Mar, 2020 at 07:11:11pm
do you have a boost pressure signal pipe connected from the inlet box on the carb ,to the fuel pressure regulator ? Medusa + injection = too much torque for the dyno ..https://youtu.be/qg5o0_tJxYM |
29th Mar, 2020 at 07:19:19pm
Yes, got a pipe going from the plenum chamber to the pressure reg for boost signal |
30th Mar, 2020 at 07:14:24am
coolio , well the pressure should deff not be dropping ,so i would focus on the fpr , do you have a piccy of how its connected up ? and of the carb ? Medusa + injection = too much torque for the dyno ..https://youtu.be/qg5o0_tJxYM |
30th Mar, 2020 at 08:03:28am
As Robert says. I wonder if the fpr reference is coming from the wrong place? It needs to come off the plenum not the inlet.
30th Mar, 2020 at 09:37:23am
Would dropping fuel pressure cause the issue above though? Wouldn’t it need to empty the float bowl before a problem surfaced.
In the 13's at last!.. Just |
30th Mar, 2020 at 11:56:23am
Thanks for the replies everyone.
30th Mar, 2020 at 12:27:55pm
I should also say theres a standard BDD needle in there! |
30th Mar, 2020 at 12:36:38pm
what needle is in the carb , its hard to see is that blue pipe from the top of the fpr going into the corner stub on the plenum ? what do the plugs look like . Medusa + injection = too much torque for the dyno ..https://youtu.be/qg5o0_tJxYM |
2646 Posts Member #: 1246 Post Whore Lowestoft, Suffolk. |
30th Mar, 2020 at 12:39:10pm
With a pressure gauge inline inbetween the regulator and carb, what happens to your 3.5 psi base pressure if you apply pressure (say 10 psi via an air line or foot pump) to the boost reference on the fpr?
Edited by shane on 30th Mar, 2020. |
21 Posts Member #: 11807 Member |
30th Mar, 2020 at 12:46:32pm
Long time ago, sure had similar on my turbo van, was the vent solenoid not closing, from memory, but that was 25 years ago.
30th Mar, 2020 at 01:41:39pm
its the standard BDD needle in there at the moment. I'll have a go testing the regulator and see what happens. I think it must be working though as on boost the afr is good so the fuel pressure must rise with boost, its just any slightly quick movement with the throttle and it goes lean and bogs down.
30th Mar, 2020 at 02:15:20pm
starts to sound like the needle needs to meet mr file :) Medusa + injection = too much torque for the dyno ..https://youtu.be/qg5o0_tJxYM |
30th Mar, 2020 at 02:30:20pm
On 29th Mar, 2020 Glun34 said:
5w-30 dashpot oil. Try thick oil, 20w50
31st Mar, 2020 at 11:40:58am
Ok I'll try some ticker dashpot oil like 20w50 and see what difference it makes.
31st Mar, 2020 at 12:08:08pm
only try one thing at a time otherwise you won't learn what has cured it.
31st Mar, 2020 at 10:57:11pm
Ok, put some thicker 20W50 in there this afternoon and it had the same problem again! Any reasonably quick movements with the throttle and it would lean out straight away. I did just out of interest put some 3 in one into the dashpot after that to see what would happen and again of course I had the same problem.
Edited by Glun34 on 1st Apr, 2020. |
1st Apr, 2020 at 05:15:09pm
Don’t rule out needle profile. It could certainly still be the culprit.
3rd Apr, 2020 at 12:00:57am
Ok, so today I tired blocking off the servo connection on the manifold to see if it was leaking, but still the same issue. Goes lean at any sight quick throttle usage. Then got out some vacuum gauges I have for balancing bike cabs and connected one to the dizzy vacuum advance connection on the top of the carb. Saw no drop in vacuum on throttle so I can only guess from that there’s no leak in the system.
3rd Apr, 2020 at 07:31:52am
what fuel pump are you using?
My build thread..
3rd Apr, 2020 at 08:09:15am
Did you fit a pressure gauge between the regulator and the carb' and prove that the fuel pressure rises with boost from the 3 /4 psi base pressure?
Edited by shane on 3rd Apr, 2020. |
7th Apr, 2020 at 09:32:51am
Have you tried blocking off the part throttle lean off pipe? It causes this exact problem when playing up. You can test the theory by just clamping the pipe and going for a drive.
40 Posts Member #: 10334 Member Staffordshire |
20th Mar, 2023 at 10:35:50pm
Mine was the choke O rings in the carb |
21st Mar, 2023 at 09:10:01am
Okay. My question is this what are the fuel tank feed and return line bore sizes?
Edited by Mr Joshua on 21st Mar, 2023. Own the day
